Budget upgrade £300 - What would you do?
So this is they way to go then?
I know this has been advised at the beginning but its good to go through the motions.
Your basket
Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W)£179.99
Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £84.98
GeIL Black Dragon 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit £31.19
Total : £307.56
Including Delivery
It will be a huge upgrade :)
Really is worthing getting an SSD next, the difference in performance compared to a hard drive is staggering.
Hi guys and girls, I'm looking for a little advice. I'll save you the background story but needless to say I wish to upgrade what I have and have a budget of £300 max. Based in the UK.
MY current specs are:
CPU: AMD Athlon 64 X2 4200+
Motherboard: Gigabyte M68M-S2P
Ram: DDR2 4GB - 2x 2GB Kingston PC2-5300
Graphics: NVIDIA GeForce GTS450 1GB
PSU: Corsair TX 650w
HDD: 2x 500GB Seagate SATA
I'm running windows 7 64bit ultimate and would like to be able to play some of the newer games, which I'm finding my old CPU it's struggling to do. I also play with a bit of video editing and music creation and general basic coding etc. this is not just my gaming/work rig but also my HTPC so need it to run blu-ray smoothly and ideally optical audio to my receiver.
So with a budget of £300 what would you do?
Thanks
It is a pity you said 300 max , the i5 or i7 would be better for the video editing.
I am getting an i7 myself for my new build because my brother does video editing.
That's the problem with kids, they eat all your spare cash!
So now a case of finding the deals.
i5-3570K - Someone else - £156.99
Z77-D3H - Someone else - £79.06
GeIL Black Dragon 8GB - Overclockers - £31.19
TOTAL: £267.24
If I can find another £35 saving I can get an SSD too.
i5-3570K - :( - £174.94
Z77-D3H - :( - £79.06
TOTAL: £285.19
Best remove the competitor links before a mod sees them. It`s against forum rules. Just a friendly warning.;)
