gelid do a mini pwm to normal pwm adaptor - then you'd just need to cut the 12v and splice in one from a molex adaptor
why is it so important? if you're running water, you don't really need to turn the fans up...
at the moment mine goes from 20% at idle to 40% IF cpu temps get near 90. gpu's never get anywhere near as hot
