If you can double those lifts in 12 months, I'm quitting the gym.
If I can hit half that, I'll be pretty impressed.
Keep it up.Impressive front squats considering your back squats are only 120kg.
In terms of doubling? No. Even 50% increase would be unlikely.![]()
Keep it up.
Just made up this for myself today, calculator spreadsheet for 531 just put in 1RM (the 90% is automated so use real 1RM)
https://docs.google.com/open?id=0B6iWbDXsFspBRm45emF1R3lJUEk
hope it helps those lazy like me
another good day at the gym apart from messing up my times so had to miss my 4th set off the deadlifts, did see yet more odd goings on in the gym, some guy rocks up to a pull up bar and use straps on it ?! he did the pull up's easy enough so god knows why he needed straps.
To be fair I've used straps for pull because my grip sits under my long as hell fingers and goes well before my arms or back give out.
I know its seen as **ssy but I'd have a crappy has hell workout without em![]()
yeah but avoid it too much and you have a problem long term. i can grip plenty but when i want to engage the back more than the biceps i like to pull with loose hands. i will however raw grip 90% of everything.
GAC - 8 reps is all well and good, but is it a struggle? Or are you getting all the reps out ok? I'd suggest that unless you're struggling towards the end it may be too light....
.It will continue to be weak as long as you use the straps. Leave them at home for a month and do some grip work.I know, you're right. Grip is weak![]()
beef jerky (Second best thing ever)
