This hardware on a 500W PSU. Is it a bad move?
Caporegime
29 Jul 2011
In acme's chair.
Will an OCZ CoreXstream 500w have enough guts to power:
i3 530 @ stock 2.93GHz
8gb (2x4gb) 1333MHz Ripjaws
GTX480 @ stock w' stock cooler
1x HDD
1x Optical drive
Cheers. :)
24 Dec 2011
I can't see why not, If you start adding more graphics cards or overclocking anything in future then change it. I would personally go for a more reputable PSU though like Coolermaster, XFX, Corsair
21 Apr 2012
Bristol
500W is enough however I do know the 4 series GPU's (or at least the 470) was very power hungry under load and if you overclock that thing I would definetley get something like a Seasonic 600W PSU.
Caporegime
OP
29 Jul 2011
In acme's chair.
I ask because there is a small chance that I'm getting an HD7950 in a few days, and if I do, my friend would like to buy my GTX480 for his rig. (specs as above but with an HD5770 currently)
Caporegime
OP
29 Jul 2011
In acme's chair.
The HD7950 would be for my rig running on a 700W PSU if you read my post properly haha :p
What about the same question as before, but with a 500W StealthXstream II? Same story there?
Got those PSU's to choose from already.
His system draws around 280W peak with the 5770 connected. (everything at 100% on stock clocks)
1 Apr 2009
StealthXStream II 500W is worse, at least spec-wise. It's ok for a 5770, but not for a 480. Most likely instability and reboots will occur.
Yes is enough nice build
Really? Would YOU do it? I certainly wouldn't.
