Which Graphics Card with 550W PSU
18 Oct 2012
Hi guys, i recently bought the Radeon HD 7850 OC Windforce. Whilst gaming the card kept crashing my system at random times and freezing my system making it unusable.
I contacted support and am returning it as i was told the PSU wasn't powerful enough for the HD 7850.
My PSU is the OCZ ZT Series 550W, i was wondering if anyone could suggest a similar GPU that will work with this power supply or is it worth replacing all together?
Will just add that i'm I am only a casual gamer and looking for a card around £150ish.
Many thanks
OP
18 Oct 2012
To be honest i don't think support we're really that interested, as soon as i said i had a 550W PSU that was it without really diagnosing the problem.
Perhaps i just have a bad card or its not compatible with my setup. Everything is relatively new tho and i just want to get up and running rather than sending the card back and having to wait for testing etc...
OP
18 Oct 2012
Well i'm glad it isn't the PSU then. I think I am just going to send it back for a refund anyways as there is a problem somewhere, hopefully it is just a defect with that card as the rest of the system is running fine.
Once I get refunded has anyone got any suggestion for a similar spec card? I have been put off the radeon HD series after this.
5 Mar 2012
Ipswich
I would guess you have a problem somewhere else. Perhaps the card itself was fine, its hard to say without trying on someone elses computer or trying a few other things. If you are in the DSR period though you are best off returning it :)
10 Apr 2008
If you're not interested in AMD, then probably something like this:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-177-MS&groupid=701&catid=1914&subcat=1854
The 560Ti performs quite close to a 570, which eats a 7850 for breakfast.
OP
18 Oct 2012
Yes exactly, the motherboard, processor, PSU, case and memory were all new and only installed 2 weeks ago and everything seemed okay. The graphics card was the last thing to arrive and added on tuesday when the problems started.
I have tried 3 different hard drives with new windows installions but still with no luck.
Its just so frustrating after saving up and waiting for so long and then things not working correctly :/
8 Sep 2012
It's definitely not your PSU, don't listen to such ********. I'm running an oc'd 7850 with an oc'd Phenom II 955 BE, 1TB HDD and 4 case fans on a 500W OCZ PSU with no problems whatsoever. I'd say that either the card is faulty or AMD drivers are playing up (maybe your 2d/3d clocks are changing during gameplay or something).
OP
18 Oct 2012
Yeah its kinda stange, i can play on skyrim for an hour sometimes with no problem but then sometimes it will only last 5 minutes. I didn't manage to get that far to explain the actually problem with support.
I've read about a few problems with this card relating to drivers etc but after 2 days of trying different things i'm ready to give up.
I am just happy that its not the PSU which is at fault.
30 Mar 2010
Under The Stairs!
+1, probably the best your going to get for the money.
This bit on the other hand:
8454. 580. 3930K @ 4.6 --------- Rossi
8370. 580. 2600K @ 5.2 --------- Geeman1979
8299. 670. 2500K @ 0.0 --------- Kronos
8279. 7850. 2600K @ 4.5 -------- Wazza300
8043. 660TI. 960T @ 4.1 -------- Imginy
7944. 7850. 3930K @ 4.5 -------- Boomstick777
7924. 7870. IIX6 @ 4.2 ---------- Humbug
7899. 470. 3770K @ 5.5 --------- 8 Pack
7649. 670. 955BE @ 3.8 --------- Madtoady
7571. 7870. I7 860 @ 3.7 --------- AlmostStew1990
7514. 460. 3770K @ 6.0 --------- 8 Pack
7508. 7870. 2500K @ 4.5 -------- Spenty
7244. 7850. 3570K @ 4.8 -------- Gibbo GTI
6470. 7850. 3570K @ 3.5 -------- Arekgreenman888
6415. 560TI (448). 2500K @ 4.4 - Leoncao
6357. 560TI (448). 3570K @ 4.4 - Yjani
6137. 7870. II 965 @ 3.4 -------- Ryan4227
6116. 570. I7 920 @ 3.6 --------- Subaru Swift
6083. 470. 3570K @ 4.2 --------- Pulse
6054. 6970. FX8120 @ 4.9 ------- Angelbambi
6041. 570. 3570K @ 3.4 --------- SkeeterUK
5613. 560TI. 2500K @ 4.5 ------- WhyScotty
5458. 680. E8500 @ 0.0 --------- The Mad one
5227. 7850. I3 @ 3.0 ------------ Wazza300
5207. 560TI. 2500K @ 4.6 ------- Neil79
Take into account 3DMark on the whole runs better on Nvidia
