Heaters use tons of electricity, no battery is going to be able to power them for any significant length of time. The biggest leisure batteries are 250Ah at 12v. Unless you want to build a massive battery from 18650 lithium-ion cells this idea is a non starter. Electric heating is absurdly expensive even if it's underfloor heating, use gas or a log burner instead.
UPS's are very expensive for the meagre capacity they provide, you shouldn't base any cost estimates on them.
It isn't going to be worth it. the batteries will cost more than you will save. You would also need a huge amount of batteries. Look at UPS for example. They cost loads and only power a computer for minutes. High powered stuff isn't going to last long at all on a battery.
