12 Nov 2012 at 23:58 #21 pryere pryere Associate Joined 27 Feb 2012 Posts 528 Location The Big Smoke I have one of mine just resting on a hdd (it's not going anywhere). That would worry me. Heat.
13 Nov 2012 at 00:01 #22 wazza300 wazza300 Caporegime Joined 11 Jul 2009 Posts 27,040 Location BenefitStreetBirmingham just stick it to the roof of your case with some chewing gum,problem solved
13 Nov 2012 at 12:39 #23 unleashed unleashed Associate Joined 9 Jan 2012 Posts 463 You really can't beat gaffer tape
13 Nov 2012 at 12:41 #24 Mel_P Mel_P Soldato Joined 27 Feb 2004 Posts 2,586 Location Kent Just let it all hang loose!
13 Nov 2012 at 12:47 #25 Paul11 Paul11 Soldato Joined 28 Sep 2003 Posts 10,414 Location London mines hanging , no problem
13 Nov 2012 at 14:54 #26 bledd bledd Don Joined 21 Oct 2002 Posts 46,863 Location Parts Unknown I just chuck them in any hole they fit (that's what she said)
14 Nov 2012 at 00:31 #27 Menty Menty Associate Joined 3 Jan 2011 Posts 539 Location Tipton pryere said: I have one of mine just resting on a hdd (it's not going anywhere). That would worry me. Heat. Click to expand... Erm what? If your hdd's run hot your system must be unique! Mine has only one front intake fan and temperatures are negligible. Last edited: 14 Nov 2012
14 Nov 2012 at 01:42 #28 Jay85 Jay85 Soldato Joined 22 May 2010 Posts 12,987 Location Minibotpc I have mine velcroed down lol
14 Nov 2012 at 12:27 #29 ntg ntg Associate Joined 24 Nov 2008 Posts 2,499 cant you just use a magnet to make it stick on the case?
14 Nov 2012 at 12:43 #30 unleashed unleashed Associate Joined 9 Jan 2012 Posts 463 ntg said: cant you just use a magnet to make it stick on the case? Click to expand... Not if the case is aluminium....gaffer tape, gaffer tape
14 Nov 2012 at 12:49 #31 ntg ntg Associate Joined 24 Nov 2008 Posts 2,499 unleashed said: Not if the case is aluminium....gaffer tape, gaffer tape Click to expand... you can place a magnet on the outside too! win!
14 Nov 2012 at 13:13 #32 unleashed unleashed Associate Joined 9 Jan 2012 Posts 463 ntg said: you can place a magnet on the outside too! win! Click to expand... Magnetic fixing would not work with drives made from non ferrous material.....Gaffer tape works with drives irrespective of material gaffer tape...gaffer tape...gaffer tape wins every time
14 Nov 2012 at 22:15 #33 andy_mk3 andy_mk3 Soldato Joined 5 Oct 2009 Posts 14,577 Location Spalding, Lincs Zalman Z9 case wins even more
14 Nov 2012 at 22:19 #34 Egon Egon Soldato Joined 9 Jan 2003 Posts 6,805 Location Darlington My last one was taped on. The upgrade is a dangler.
14 Nov 2012 at 22:27 #35 inogen inogen Soldato Joined 19 Jul 2009 Posts 7,410 My c300 was a dangler... Was fine... New 520 is screwed in nice!
15 Nov 2012 at 06:10 #36 unleashed unleashed Associate Joined 9 Jan 2012 Posts 463 andy_mk3 said: Zalman Z9 case wins even more Click to expand... It's mounted upside down....will it still work
15 Nov 2012 at 07:06 #37 steve258 steve258 Soldato Joined 3 Jan 2006 Posts 5,009 panyan said: mine is shoved in the back with the cabling Click to expand... +1
15 Nov 2012 at 11:17 #38 -Ad- -Ad- Soldato Joined 4 Nov 2004 Posts 14,487 Location Beds Blu tac'd mine into the base of the floppy drive internal case caddy.
17 Nov 2012 at 08:16 #39 mranderson mranderson Associate Joined 29 Jul 2008 Posts 1,416 passey89 said: no. just don't throw ur pc around Click to expand... That with some blu-tack so it doesn't rattle
18 Nov 2012 at 07:59 #40 IceUK IceUK Associate Joined 26 Oct 2006 Posts 168 I wouldnt screw it down no point just tuck in away in the case somewhere
