**GIBBO's WEEKEND SPECIALS: PERFECT FOR CRIMBO OR JUST TREAT YOURSELF!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Well its that time of year, people are planning their Christmas spend, presents etc. etc.
As such I've got some great deals for you for THIS WEEKEND ONLY, which shall expire midday Monday:-
AMD Piledriver FX-8 Eight Core 8350 Black Edition 4.00GHz (Socket AM3+) Processor - Retail @ £149.99 inc VAT
The new AMD FX 8-Core Processor is now faster than ever! It’s still unlocked for your overclocking pleasure, and it’s still the only 8-core desktop processor around. AMD FX processors have broken records before and now it’s your turn. Experience unmatched multitasking and pure core performance with a new architecture and great prices.
Features:-
- The next-generation architecture takes 8-core processing to a new level. Test the limits to play harder and get more done.
- Get up to 24% better frame rates in some of the most demanding games, at stunning resolutions.
- Incredible speed out of the box and more in the tank; AMD Turbo CORE Technology automatically kicks in, boosting performance to a user’s varied workload.
- Get faster audio encoding so you can enjoy your music sooner.
- The groundbreaking AMD FX 8-Core Processor Black Edition comes unlocked. No premium to pay. No code to input. Just unrestrained, overclockable power right away.
- Go up to 5.0 GHz with aggressive cooling solutions from AMD, High-end air-cooling or H20 solution required for 5.0GHz and beyond clock speeds.
- With more speed than ever and more aggressive price points – New AMD FX Processors raise the bar for 8-core computing.
- Get up to 22% better frame rates than the previous generation in some of the most popular games.3
Specification:-
- Multiplier Unlocked
- Eight Core Technology
- 4.00GHz Clock Speed
- 4.20GHz Turbo Clock Speed
- 5.2 GT/s System Bus
- AM3+ Socket
- 8MB L2 Cache
- 8MB L3 Cache
- 64-Bit Technology
- TDP: 125W
- Voltage: 0.9375v - 1.4125v
- 32nm technology
- Support upto 2400MHz DDR3
- HyperTransport 3.0 Technology
- AMD Virtualization (AMD-V) Technology
- 3 Year Warranty
- Heatsink & Fan Included
- Upto 7% faster than previous FX-8150
Was [£179.99] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Intel Core i7-2700K 3.50GHz (Sandybridge) Socket LGA1155 Processor - Retail @ £199.99 inc VAT
Intel's new Sandybridge based CPU's is a complete new refresh that requires new socket LGA1155 mainboards. This new platform uses less power and has vastly superior integrated graphics. The HD2000 graphics is capable of all multimedia task featuring DirectX 10.1 runtime making them ideal for gamers too. The K series edition processors are unlocked on the multiplier allowing overclocking and also feature HD3000 onboard graphics which feature twice the horsepower of the HD2000 making them ideal for gamers and have support for 3D Gaming. The new Sandybridge K series processors also feature immense overclocking as well.
- Lithography Process: 32 nm
- Cores: 4
- Threads: 8
- Frequency: 3.50 GHz (Turbo Mode 3.90GHz)
- Integrated HD 3000 (12 EUs) Graphics
- Integrated Graphics Frequency: 850MHz (1350MHz Turbo)
- Cache: 8 MB shared L3
- Memory Controller: Dual channel DDR3 800/1066/1333/1600 MHz
- TDP: 95W
- Socket: LGA1155
- Compatible with Socket 1156 heatsinks
- 3yr Warranty
***OVERCLOCKING GUIDELINES***
- Do not exceed 1.425v core voltage, doing so could limit lifespan of the CPU
- Aim to keep temperatures below 70c underload if at all possible
- Do not overclock with BCLK, again doing so could limit lifespan of the CPU
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher than 1.60v could limit lifespan of the CPU
- These recommendations come from OcUK and Intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your CPU lifespan is un-affected
- All Sandybridge CPU's worldwide should be run at the above or lower voltages, no higher!
Was [£259.99] Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-17000C11 2133MHz Dual CHannel Kit (PV38G213C1K) @ £31.99 inc VAT
Patriot Memory’s Viper 3 Series memory kits are designed with true performance in mind. Tested and compatible with Intel’s® DDR3 compatible processors and chipsets, The Viper 3 series provides the best
performance and stability for the most demanding computer environments.
The Viper 3 series utilizes a custom designed high performance heat shield for superior heat dissipation to ensure rock solid performance even when using the most taxing applications. Built from the highest quality Build of Materials, Patriot Memory’s Viper 3 Series memory kits are hand tested and validated for system compatibility.
Available in dual and quad channel kits, 8GB, 16GB and 32GB Kits, Patriot Memory’s Viper 3 Series will be offered at speeds from 1600MHz up to 2133MHz at 1.5 volts and are XMP 1.3 ready. Hand tested for quality assurance, the Viper 3 series is backed by a lifetime warranty.
- Extreme Performance PC3-17000 (2133MHz)
- Enhanced Latency (11-11-11-30)
- Voltage: 1.5V
- XMP 1.3 Ready
- Equipped with an extruded aluminum shield build around a copper core to provide improved cooling
- 100% Tested and Verified
- RoHS Compliant
- Tested on Intel® P67 and Z77 platforms
Was [£43.99] Inc. VAT
Only £31.99 inc VAT.
ORDER NOW
Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit (PV38G186C9K) @ £29.99 inc VAT
- Extreme Performance PC3-15000 (1866MHz)
- Low Latency (9-9-9-24)
- Voltage: 1.5V
- XMP 1.3 Ready
- RoHS Compliant
Was [£53.99] Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (PV38G160C9K) @ £26.99 inc VAT
Patriot Memory’s Viper 3 Series memory kits are designed with true performance in mind. Tested and compatible with Intel’s® and AMD’s DDR3 compatible processors and chipsets, The Viper 3 series provides the best performance and stability for the most demanding computer environments.
The Viper 3 series utilizes a custom designed high performance heat shield or superior heat dissipation to ensure rock solid performance even when using the most taxing applications. Built from the highest quality Build of Materials, Patriot Memory’s Viper 3 Series memory kits are hand tested and validated for system compatibility.
Available in dual and quad channel kits, 8GB, 16GB and 32GB Kits, Patriot Memory’s Viper 3 Series will be offered at speeds from 1600MHz up to 2133MHz at 1.5 volts and are XMP 1.3 eady. Hand tested for quality assurance, the Viper 3 series is backed by a lifetime warranty.
- Extreme Performance PC3-12800 (1600MHz)
- Voltage: 1.5v
- XMP 1.3 Ready
- RoHS Compliant
Was [£31.99] Inc. VAT
Only £26.99 inc VAT.
ORDER NOW
Patriot Viper "Black Mamba" Generation 3 16GB (2x8GB) DDR3 PC3-12800C9 1600MHz Dual Channel kit (PV316G160C9K) @ £59.99 inc VAT
- Voltage: 1.5V
- XMP 1.3 Ready
- RoHS Compliant
Was [£89.99] Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Samsung Green (MV-3V4G3D/US) 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz 30nm Dual Channel Kit @ £41.99 inc VAT
nonl2br
These Samsung Green kits are a world first using 30nm technology. This results in lower power usage, extended life and ultra low profile making them compatible with all DDR3 solutions including small form factor.<br/><br/>
Boost performance with Samsung genuine PC memory. As the number one memory supplier in the world, Samsung DRAM modules are made with 100% Samsung components. With the 30nm-Class DDR3 1600MHz Extreme Low Voltage UDIMM module from Samsung, you can get faster speed and greater reliability from your computer while consuming less energy. Use Samsung UDIMM DDR3 memory to replace or increase the memory in your desktop or server. This Samsung DDR3 memory module employs 30-nanometer technology and, as a result, uses up to 65 percent less power and is only two-thirds the size of conventional 60-nanometer memory modules. This version of Samsung DDR3 has a 8 GB capacity (2 DRAM modules, each with 4 GB). <br/><br/>
The other major advantage of these modules is their overclocking ability, in our own testing we achieved 2400MHz with CAS 11-11-11-28-1T timings with just 1.55v resulting in staggering levels of performance.
<br/><br/>
<strong>Features:-</strong><br/><br/>
- Model Name: MV-3V4G3D/US<br/>
- Main Board: INTEL/AMD<br/>
- System: DESKTOP/SFF<br/>
- System Type: DDR3<br/>
- M/B Chipset: INTEL P67, Z68, Z77, X79 & AMD Chipsets<br/>
- CAS Latency: 11-11-11-28 1N<br/>
- Capacity: 8GB (4GBx2)<br/>
- Speed: DDR3-1600 (PC3-12800)<br/>
- Test Voltage: 1.25-1.55V<br/>
- Registered/Unbuffered: Unbuffered<br/>
- Error Checking: Non-ECC<br/>
- Type: 240-pin DIMM Low Profile<br/>
- Warranty: Lifetime<br/>
<br/><br/>
<strong>
Overclocking Features (Not Guaranteed)</strong><br/><br/>
- 1600MHz (7-8-8-24 1N) @ 1.40v<br/>
- 1866MHz (9-9-9-27 1N) @ 1.40v<br/>
- 2000MHz (9-10-10-28 1N) @ 1.45v<br/>
- 2133MHz (10-10-10-28 1N) @ 1.45v<br/>
- 2400MHz (11-11-11-28 2N) @ 1.50v<br/>
- In our own in house testing we were able to achieve all the above clock speeds on an Asus X79 platform with 4x4GB modules (16GB total) SuperPI Stable too, 32M<br/>
Only £41.99 inc VAT.
ORDER NOW
Asus HD 7970 Matrix Platinum 3072MB GDDR5 PCI-Express Graphics Card with FREE FARCRY3, Hitman Absolution, Sleeping Dogs & 20% off MOH Warfighter PC Games @ £399.95 inc VAT
The ASUS ROG MATRIX HD 7970 continues the ROG tradition of catering to overclockers who want the fastest and smoothest performance. It meets extreme tuning needs, utilizing a TOP-selected GPU factory-set to 1100MHz. For hardware-level overvolting, customers get VGA Hotwire and the TweakIt interface, with one-press 100% fan speed settings. DIGI+ VRM digital controllers and Super Alloy Power components form the basis of massive 20-phase power delivery. Exclusive GPU Tweak has been enhanced for ROG duty, adding GPU loadline calibration and VRM tuning to an already full range of parameters.
DIY modification of voltages on MATRIX HD 797 becomes simple by removing the need for complicated and risky soldering. Just connect wires from dedicated headers on compatible ROG motherboards to VGA Hotwire connectors on MATRIX HD 7970, after which you can change voltages directly on the hardware level through the ASUS UEFI BIOS or via the Windows-based Ai Suite II.
TweakIt provides flexible overclocking control even when gaming or running benchmarks! The + and - buttons put overvolting adjustments at your fingertips, with more power translating into the faster and smoother gaming you crave and the winning edge you require for intense multiplayer and competitive benchmarking.
Instantly trigger the dual 100mm fans to 100% speed regardless of driver settings. This proves very useful in extreme overclocking and other heavy workload scenarios where rapid heat evacuation and max cooling are a must.
The Safe Mode button resets the graphics card back to default frequencies and BIOS settings. This is a very useful feature for hardware enthusiasts and experimental tuning - think of it like the motherboard's clear CMOS function.
MATRIX HD 7970 is built with carefully-designed massive 20-phase power delivery, unmatched by any other graphics card for the ultimate in performance and spectacular power delivery. This ensures ample room for experimental performance tuning, as its DIGI+ VRM digital voltage regulation design augments precision overclocking capabilities, which are further supported by the use of hardened Super Alloy Power capacitors, chokes, and MOSFETs. These components are forged under extreme pressure and temperatures to increase reliability, power output, and overall card lifespan while eliminating bothersome choke buzzing noise, unlike much tamer reference cards. All these and more enable the absolute best in overclocking potential and experience.
ASUS DirectCU thermal design utilizes all-copper heatpipes so heat is removed efficiently. DirectCU II generates 6X greater airflow yet performs 3X quieter than reference in idle and full load thanks to dual 100mm sound-dampening fans.
A color-coded LED MATRIX indicator at the back of the ROG MATRIX graphics card gives real time and easy-to-understand visual display of the current GPU workload, with colors changing dynamically depending your card’s work load.
Easily fine-tune core and memory clocks, voltages, and fan settings intuitively via sliders or manual value entry. MATRIX HD 7970 arrives with a new ROG edition of GPU Tweak, which adds detailed GPU loadline calibration and VRM frequency tuning, allowing for the most extensive control and adjustment parameters for maximum overclocking potential.
Features:-
- TOP-selected 1100MHz cores run 175MHz higher than reference for smoother gameplay.
- All new MATRIX thermal design utilizes six all-copper heatpipes and 20% bigger dissipation area, achieving 20% cooler and 14dB quieter performance than reference
- Acclaimed DIGI+ VRM with 12-phase Super Alloy Power technology delivers precise digital power and enhanced durability for stable overclocking
- VGA Hotwire allows you to plug and solder wires on the card’s voltage regulators and accurately read and control Vcore, Vmem, and PLL voltages on a hardware level
- GPU Tweak utility helps you modify and tune clock speeds, voltages, and fan performance via an intuitive interface
- One card drives up to six screens with AMD Eyefinity™ 6
- ROG GPU Tweak suite offers the world's first graphics overclocking tool with loadline calibration and VRM overclocking.
Specification:-
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Fastest single GPU graphics card on the planet
- Hugely overclockable
- Vastly cooler running than previous generation
- Quieter running than previous generation
- Compute Power: 3.5 TFLOPS
- Core Clock Speed: 1050MHz
- GPU Boost Speed: 1100MHz
- Primitive Rate: 2 prim / clk
- Shader Architecture: GCN
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 6600MHz
- Load / Idle Board Power: <300W / <3W
- Power Connectors: 8-pin + 8-pin
- 20 Phase super alloy design
- Display Outputs: 2x DVI + 4x DP
- 3yr Warranty
- All Orders placed on the 22nd October 2012 and after shall recieve FREE copies of FARCRY3, Hitman Absolution, Sleeping Dogs PC Games along with 20% off the latest Medal of Honor WarFighter. This bundle is worth in the region of £100 and is completely FREE (Subject to availability) - You will recieve your gamecode from 2nd November onwards in the email address you provided when placing your order!
Was [£429.95] Inc. VAT
Only £399.95 inc VAT.
ORDER NOW
Gigabyte ATI Radeon HD 7970 Windforce 3X 3072MB GDDR5 PCI-Express Graphics Card with FREE FARCRY3, Hitman Absolution, Sleeping Dogs & 20% off MOH Warfighter PC Games @ £319.99 inc VAT
GIGABYTE introduces the latest exclusive "Triangle Cool" Technology to reach a better cooling performance. The latest patent pending technology combines fin with clip module in a special triangle shape. With the original anti-turbulence structure plus the new triangle cooling design, it enhances the efficiency of heat dissipation dramatically by minimizing the flow of turbulence between fans. Therefore, the "Triangle Cool" Technology provides a more efficient air flow for the cooling system.
Ultra Durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB. GIGABYTE Ultra Durable VGA can lower GPU temperature by 5% to 10%.
Ultra Durable VGA board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability. GIGABYTE Ultra Durable VGA graphic accelerators improve overclocking capability by 10% to 30%.
Ultra Durable VGA board allows more bandwidth for electron passage and reduces circuit impedance. The less circuit impedance, the more stable flow of current and can effectively improve power efficiency. GIGABYTE Ultra Durable VGA can lower power switching loss by 10% to 30%.
Features:-
- Core Clock Speed: 1000MHz
- Memory Width / Speed: 384 bit / 5500MHz
- Power Connectors: 8-pin + 6-pin
- Dimensions: H=38 mm, L=285 mm, W=126 mm
- Display Outputs: 1xDVI + 2x mDP + 1x HDMI
- 3yr Warranty
Was [£349.99] Inc. VAT
Only £319.99 inc VAT.
ORDER NOW
Gigabyte ATI Radeon HD 7970 GHz Edition Windforce 3X 3072MB GDDR5 PCI-Express Graphics Card with FREE FARCRY3, Hitman Absolution, Sleeping Dogs & 20% off MOH Warfighter PC Games @ £359.99 inc VAT
Features:-
- Core Clock Speed: 1100MHz
- Memory Width / Speed: 384 bit / 6000MHz
- 3yr Warranty
Was [£389.99] Inc. VAT
Only £359.99 inc VAT.
ORDER NOW
Gigabyte ATi Radeon HD 7950 Windforce 3X 3072MB GDDR5 PCI-Express Graphics Card with FREE FARCRY3, Hitman Absolution, Sleeping Dogs & 20% off MOH Warfighter PC Games @ £249.95 inc VAT
Features:-
- Core Clock: 900MHz
- Memory: 3072MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 1792
- Bus Type: PCI-Express 3.0
- Display Connectors: 1x Dual Link DVI, 1x HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Warranty: 3 Years
Only £249.95 inc VAT.
ORDER NOW
Samsung S22B300HS 22" Widescreen LED Monitor - Glossy Black @ £107.99 inc VAT
Experience amazing new levels of colour, brilliance and picture quality through the very latest in Mega Dynamic Contrast Ratio. Samsung SB300 monitors deliver images so real-to-life that it will transform your whole viewing experience. Packed with breathtaking 5000000:1 contrast ratio, the highest level currently available, the SA300 monitor ensures that blacks are at their absolute darkest and (with pristine whites) colours are at their brightest. You will immediately notice the crystal clear picture and its unbelievable intensity. It is like an explosion of colours and leaves other screens seeming dull in comparison. So, take your viewing pleasure to the next level with Samsung Mega Dynamic Contrast Ratio – and enjoy your multimedia content with the professionalism it deserves.
Eco saving makes saving energy easy. It adjusts the brightness of your Samsung monitor based on how much energy you want to save. And with the choice of three energy saving modes (50%, 25% and Power Saving off), you can really tailor your monitor use to meet your own personal needs. Samsung’s commitment to saving energy is designed to help both you and the environment, and with up to 50% saving on consumption, you can really make a positive impact on your eco footprint. Take the effort out of saving energy and take control with Eco saving.
Specification:-
- Screen size: 21.5" (16:9)
- Backlight type: LED
- Brightness: 250cd/m2
- Contrast ratio: Mega DCR (Static 1000:1)
- Resolution: 1920x1080
- Response Time: 5ms
- Viewing angle: 170/160
- Colour supprt: 16.7M
- Connections: 1x D-Sub, 1x HDMI
- Warranty: 3yr
Was [£119.99] Inc. VAT
Only £107.99 inc VAT.
ORDER NOW
Iiyama Prolite E2481HS-B1 24" Widescreen LED Super Slim Bezel Monitor - Black @ £159.95 inc VAT
The ProLite E2481HS is a 24’’ Full HD 1920 x 1080p LED-backlit monitor with super slim (7 mm) bezel. It features 2ms response time and >5 000 000 : 1 Advanced Contrast Ratio assuring clear and vibrant picture quality. Triple Input support of Analogue, DVI and HDMI ensures compatibility with the latest installed graphics cards and embedded notebook outputs. The monitor is Energy Star and TCO Certified. A reliable solution for all kind of work environments where best performance is desired.
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product. With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor. Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games. This LED monitor is equipped with two high quality stereo speakers. HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals. When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that. VESA mount compliance means you can easily mount your monitor to a wall.
Specification:-
- Diagonal: 23.6"
- Panel: TN, LED-Backlit
- Display area h x w: 293.22 x 521.28 mm; 11.5" x 20.5"
- Response time: 2 ms
- Contrast: 1000 : 1 typical
- Contrast: 5 000 000 : 1 ACR
- Brightness: 250 cd/m² typical
- Viewing zone: horizontal/vertical: 178°/ 170°; right/left: 89°/ 89°; up/down: 85°/ 85°
- Display colour: 16.7 million
- Pixel pitch h x v: 0.2715 x 0.2715 mm
- Native resolution: Full HD 1080p, 1920 x 1080 ( 2.1 megapixel)
- Horizontal sync: 24 - 80 KHz
- Vertical sync: 56 - 75 Hz
- Synchronization: Separate sync
- Aspect ratio: 16 : 9
- Input connections: VGA, DVI-D & HDMI
- Speakers: 2 x 2 W (Stereo)
- Anti-theft-device: Kensington-lock™ prepared
- Certificates: CE, CU, TUV-GS, TCO
- Tilt angle: 21° up; 4° down
- VESA mounting: 100 x 100 mm
- Warranty: 3yr
Only £159.95 inc VAT.
ORDER NOW
Iiyama Prolite B2481HS-B1 24" Widescreen LED Super Slim Bezel Monitor - Black @ £179.99 inc VAT
The ProLite B2481HS is a high specification 24’’ Full HD 1920 x 1080p LED-backlit monitor with super slim (7 mm) bezel. It comes with a 13cm Height Adjustable Stand which supports Screen Rotation, ensuring perfect posture and optimal viewing which makes it ideal for Video Conferencing, DTP and CAD as well as the usual text based applications. It features 2ms response time and >5 000 000 : 1 Advanced Contrast Ratio assuring clear and vibrant picture quality. Triple Input support of Analogue, DVI and HDMI ensures compatibility with the latest installed graphics cards and embedded notebook outputs. The monitor is Energy Star and TCO Certified. A reliable solution for all kind of work environments where ergonomics and best performance are desired.
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product. With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor. Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games. This LED monitor is equipped with two high quality stereo speakers. HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals. When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that. VESA mount compliance means you can easily mount your monitor to a wall. Screen rotation means you can change the position of the screen from landscape into portrait. This feature can be very handy while working with long spreadsheets or texts. A Height Adjustable Stand allows you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort which benefits not only your health but also productivity.
Specification:-
- Diagonal: 23.6"
- Input Connections: VGA, DVI-D & HDMI
- Height adjustment: 130 mm
- Rotation (pivot function): 90°
- Swivel Stand: 320°; 160° left; 160° right
- Tilt angle: 22° up; 5° down
- Warranty: 3yr
Was [£199.99] Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
Samsung S24B300HL 23.6" Widescreen LED Monitor - Black @ £122.99 inc VAT
How do you like to watch movies? Do you like lying down on the couch? Sitting in your favorite chair? Cooking or exercising? Whether you’re standing, sitting or lying down, Samsung Magic Angle makes sure that the movie always takes center stage and that you’re always comfortable. This means, thanks to the 5-mode angle management, that whatever angle you watch your Samsung monitor, you will enjoy a full visual experience with amazing picture clarity. So, start seeing your favourite movies and other multimedia in total comfort and without limitations thanks to Magic Angle.
Eco saving makes saving energy easy. It adjusts the brightness of your Samsung monitor based on how much energy you want to save. And with the choice of three energy saving modes (50%;, 25%; and Power Saving off), you can really tailor your monitor use to meet your own personal needs. Samsung’s commitment to saving energy is designed to help both you and the environment, and with up to 50%; saving on consumption, you can really make a positive impact on your eco footprint. Take the effort out of saving energy and take control with Eco saving.
Specification:-
- 23.6" (16 : 9) Screen Size
- LED Type
- 250 cd/m² Brightness
- Mega 8 DCR (Static 1000 : 1) Contrast Ratio
- 1920 x 1080 Resolution
- 5 ms Response Time
- 170° / 160° Viewing Angle (Horizontal / Vertical)
- 16.7 M Color Support
- Inputs: 1x Analogue & 1x HDMI
- High Glossy Black
- Simple Stand Type
- Tilt Stand Function
- 569 x 416 x 197 mm Set Dimension with Stand (W x H x D)
- 569 x 342 x 53 mm Set Dimension without Stand (W x H x D)
- 692 x 415 x 111 mm Package Dimension (W x H x D)
- 3yr Warranty
Was [£129.95] Inc. VAT
Only £122.99 inc VAT.
ORDER NOW
DGM IPS-2701WPH 27" LED Widescreen Professional Monitor - Black @ £311.99 inc VAT
The IPS-2701WPH is DGM's new WQHD resolution monitor built around LED backlight LG IPS panels. Featuring a 2560x1440 resolution [WQHD], these monitors are ideal for creative professionals and gamers who demand nothing but the very best. IPS panels are preferred for their superior true color values, the most consistent image and a superior viewing angle as compared to other LCD technologies.
The DGM IPS-2701WPH features the same high resolution LED LG IPS panel found in the Apple Cinema Displays. Video content bypasses scalers making the DGM IPS-2701WPH ideal for gaming and multimedia video production. The superfast 6ms response [grey to grey] minimises streaking and ghosting resulting in visibly less smear and blur around fast moving objects.
Features:-
- Panel Size: 27" Diagonal IPS Panel
- Aspect Ratio: 16:9
- Resolution: 2560 x 1440 (WQHD)
- Pixel Pitch: 0.2331 mm
- Display Colors: 16.7M
- Brightness (cd/m2): 350cd/m2
- Contrast Ratio (Typ.): 1000:1
- Dynamic Contrast Ratio (Typ.): 80,000
- Response time (ms): 6ms
- Viewing Angle, H/V: 178 degree(H) / 178 degree(V)
- Input Signal: HDMI (Max resolution on HDMI is 1920x1080), Dual Link DVI-D, DP (Display Port), VGA (D-sub 15pin)
- HDCP Support: YES
- Internal Speaker: Built-in Stereo Speakers
- Wall Mount: VESA 100 x 100 mm
- Net / Gross Weight: 7.6 / 10.3 Kg
- Monitor Dimension (W*H*D mm): 645 × 487 × 172 mm
- Carton Dimension (W*H*D mm): 720 × 510 × 130 mm
- 3yr Warranty return to base with OcUK
Was [£359.99] Inc. VAT
Only £311.99 inc VAT.
ORDER NOW
Hazro HZ30Wie 10-Bit 30" LCD Widescreen Professional Monitor - Black @ £539.99 inc VAT
The Hazro HZ30Wi is ideal for graphics and visual media, where professional grade technology meets revolutionary design. The massive 4MP (2560x1600) WQXGA resolution brings a new dimension to on-screen graphics. S-IPS display technology delivers unsurpassed levels of colour saturation. It results in image clarity that allows for colours to be easily differentiated to bring unheard of precision and accuracy in visual reproduction. Wherever you need it most, the Hazro HZ30Wi performs with consistency and clarity to optimise your visual experience. The Hazro HZ30Wi recognises groundbreaking technology without compromising efficiency, whilst tailoring to the needs of the discerning, professional, user. The masterful design outside augments the genius within, with the Hazro HZ30Wi collating top industry-spec innovation with rock-solid dependability to perform when you need it most, time and time again. With the Hazro HZ30Wi, you can view perfectly rendered images without compromising on the space you need to take your creation from conception to fruition. View an uncompromisingly crisp, and sharp, output that won't strain your eyes in a resolution and pixel pitch that'll inject life into your work with piercing detail. The Hazro HZ30Wi offers three times the workspace of a standard 19" monitor and 77% more workspace than a 24" [16:9] display - allowing creative freedom and practicality. With quicker access to colour tools, palettes and document windows, the HZ30Wi is proven to increase efficiency and output. Anyone can see the tangible results of being able to view two application windows side-by-side. Whether it's to look at a website and its code simultaneously, or if it's to streamline data-entry processes, the final result will still be improved efficiency - and, in the case of businesses, an impact on their bottom line.
Features:-
- LCD Panel: 30" WQXGA colour LCD S-IPS active matrix
- Type: 16:10 aspect Ultra wide gamut TFT-LCD
- Bit Depth: HZ30Wie: 10bit 1.07billion Colors
- Viewing area: 641.28 mm (H) x 400.8 mm (V)
- Resolution: 2560 [H] x 1600 [V]
- Pixel Pitch: 0.2505mm x 0.2505mm
- Contrast Ratio: 1000 : 1(Typ.)
- Refresh rate: 59 ~ 60 Hz
- Response Time: 6ms [grey-to-grey]
- Color Gamut: Wide Gamut 117% (CIE 1976) NTSC [100% AdobeRGB and sRGB Coverage]
- Brightness: 370 cd /m² (Center 1 Point)
- Viewing Angle: R/L : 89°/ 89°U/D : 89°/ 89° (178°/ 178°)
- Surface Treatment: Hard coating(3H), Anti-glare treatment of the front polariser
- VESA Hole Configuration: VESA 100x100 & 200x100
- Dimensions: Approx: 690(L) x 445(W) x 65mm(D) (excluding stand)
- Weight: Approx 11 kg before packaging and excluding stand [approx]
- Power Consumption: In Operation: <150W
- DPMS / OFF: <2W
- Energy Saving Mode: VESA DPMS [Display Power Management Signaling]
- Power Input/Output: DC Input: AC 100V-240V, 50~60Hz, DC Output: DC 24V / 6.3A [approx]
- Inputs: 24V DC Jack, 1 x Dual Link DVI-D;
- Accessories: 1 x Dual Link DVI-D Cable; 1 x IEC 3 Pin AC Power Cable;
- 1 x DC Power Adapter; Instruction Manual
- 3yr Warranty
- Read the TFT Central Review here of 8-bit version: http://www.tftcentral.co.uk/reviews/hazro_hz30wi.htm
Was [£699.95] Inc. VAT
Only £539.99 inc VAT.
ORDER NOW
OcUK Limited Edition P170EM 17.3" LED Full HD Intel Processor, 1600MHz DDR3, SSD + HDD, ATI HD 7970M 2GB GDDR5 Graphics Card - Windows - Black @ £999.00 inc VAT
This Limited Edition of 10 units only now makes it possible to have a state of the art hardcore gaming laptop for under £1000. Though we do recommend customising the laptop with more memory along with additional storage. But now you can have an Intel based 7970M powerhouse of a gaming laptop all for under £1000, though you can also spec the system up with options that take it beyond the £1000 price too. Rest assured the 7970M graphics in this laptop can handle any game with ease.
For hardcore gamers the OcUK Extreme P170EM is the perfect choice. There is no more powerful or better constructed option, with the latest Intel Core I7 Processor there is no shortage of power and for those who only demand the most powerful, we can construct the OcUK Extreme P170EM with an Intel I7 Extreme processor too.
This chassis uses the absolute very latest in technology such as SATA3, USB3.0, Bluetooth, WiFi but the most impressive of all is the fact this system feature an ATi Radeon 7970M with 2GB of GDDR5 dedicated memory for absolutely blistering performance. Infact this is the fastest gaming laptop we sell and more importantly its also one of the best value and offers you the ability to tailor to your exact needs.
With a backlit keyboard you will no longer have problems finding the keys during the dark or whilst playing your favourite shoot 'em up! Not only that but with a choice of colours to suit your environment and taste your notebook will look more stylish than ever!
With a LED backlit 17.3" screen with True HD (1920x1080) resolution games have never looked so good on the go or ran so smooth due to the power of the ATI HD 7970M onboard graphics. The OcUK Extreme P170EM feature a blue backlit keyboard and high quality THX speakers for the ultimate gaming experience.
For memory we only use the highest performance and most reliable for laptops, which is Corsair Vengeance which is set to run at 1600MHz with T1 memory timings resulting in absolute instant response. 8GB is the default choice which is more than adequate for all task and gaming, we only recommend 16GB kit if your also doing a lot of photography work or heavy multi-tasking. Corsair Vengeance 1600MHz will extract the very best performance from the OcUK Extreme P170EM causing zero bottlenecks in the system.
For hard drive options, we recommend the primary drive as an SSD drive, this means from point of pressing power on your should be at the Windows 7 Desktop in approx 10 seconds and with an SSD applications and games load more or less instantly. Of course if you preferre capacity you can choose a large capacity HDD or a Hybrid drive too. Our recommendation is to select an SSD for the primary drive along with a HDD as the secondary drive for storage.
Specification:-
- Operating System: Choose from the drop down options!
- Display: 17.3" SuperBright LED True HD Display (1920x1080 Resolution)
- Graphics: AMD Radeon™ HD7970M 2GB GDDR5
- Storage: Choose from the drop down options!
- Optical: Choose from the drop down options!
- HD Audio
- Mic Noise Suppression
- Dolby Home Theatre®
- 4W Stereo Speakers (2W x 4)
- Subwoofer
- 2 megapixel Webcam
- Processor: Intel® Core™ i5 / i7 Processor - Choose exact model from drop down options!
- Physical Specification: 412mm x 276mm x 41.8~45.4mm (3.9kg with battery)
- Memory: 4GB DDR3 System Memory at 1600MHz (4GB x 1) OR choose 8/16GB DDR3 Options
- Main Chipset: Intel HM77
- Communication: 10 / 100 / 1000 Gigabit Ethernet LAN,Wireless LAN, Widi Support
- Intel Centrino Wireless N 2230
- 1x HDMI Port
- 3x USB3.0 Ports
- 1x USB2.0 Port
- 1x E-SATA
- 1x DVI-I
- 1x DisplayPort
- 1x Microphone IN
- 1x Headphone OUT
- 1x DC IN
- 1x RJ-45 Jack
- 1x IEEE 1394a
- Kensington Lock: YES
- 8 Cell Smart Lithium-ION Battery
- Fingerprint Scanner
- 9in1 Card Reader
- 2yr Warranty (1yr Parts, 2yr Labour)
Service Package
- Full 24 Month collect and return warranty (12 month on parts)
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this Notebook for You?
Immense performance, powerful graphics and sleek hardware all combine to create the "OcUK Extreme P170EM", perfect for the gaming enthusiast.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
* No OS systems are fully tested with the same extensive methods as systems chosen with an operating system. Including tests such as CPU, memory and GFX stress tests. All no OS systems are formatted completely before shipping.
*Please allow between 48 and 96 hours for your system to be built and configured. This may take longer during busier periods. You can choose from the drop down options to jump the queue by selecting one of our Fast Track options. If your choosing the 24hr next day service, to get the laptop delivered next working day you need to order pre 10:30am to give us enough time to build, test and get your laptop shipped out, otherwise you will get it the following day.
Only £999.00 inc VAT.
ORDER NOW
MSI GE60 0ND-285UK Gaming Laptop 15.6" LED Full HD Intel I7-3630QM, 8GB DDR3, 750GB HDD, NVIDIA GTX 660M 2GB GDDR5 Graphics, Win7 Home Premium 64-Bit - Black @ £899.99 inc VAT
The MSI GE60 is a gaming laptop first and foremost, but rather than just repeat the marketing here's why we call it a gaming laptop:
Nvidia GeForce GTX 660M Graphics
While not the fastest mobile graphics the price/performance of the 660M is unequestionable and will power Dirt 3, Black Ops 2 or Borderlands 2 to over 60fps at the full 1080p resolution the MSI GE60 supports and for comparison to your desktop GPUs, is about as fast as a 5770 or 4870X2. This laptop is certainly capable of taking your gaming mobile. But don't take my word for it, check out this review to see if it's right for you: http://www.notebookcheck.net/NVIDIA-GeForce-GTX-660M.71859.0.html
3rd Generation "Ivy Bridge" Core i7-3630QM Quad Core Processor
Of course fast graphics rely on the processor to keep up and the latest i7 Ivybridge from Intel has no trouble on this score, as usual from Intel mobile power management is a major focus so don't worry about running out of battery while you're finishing that important document and when you plug in you can use all that power to reach the top of the score boards (or rendering your presentation if that's your thing).
Killer 2200 Series Gaming Network Card
The first laptop from MSI to feature Killer Gaming Networking, prioritises and accelerates gaming traffic to ensure you have the least lag and highest FPS. We can't promise the rest of the internet will be as good but it gives you the best possible start.
Keyboard by Steelseries
Laptop keyboards aren't known for gaming but the MSI GE60 changes this with a designed by steel Series gaming keyboard featuring enlarged gaming keys (such as WASD) for more comfortable gaming and even moving the windows key out of the way so you don't pop out of your game at the worst moment. Typical Steel Series features such as solid tactile response keys and allowing multiple keys to be pressed at once also make it to the MSI GE60 so while you may still want to bring your favourite keyboard with you to the LAN it isn't the necessity it once was.
Full Specifications
- 15.6" Full-HD non-glare 1920x1080 LED Backlit screen
- Genuine Windows 7 Home Premium
- 3rd Generation "Ivy Bridge" Intel Core i7-3630QM Quad Core Processor
- 8GB DDR3
- Nvidia GeForce GTX660M with 2GB of GDDR5 memory
- 750GB SATA Hard Drive
- DVDRW Optical Drive
- Killer 2205 Gaming Network Card
- Steelseries Keyboard
- 7.1 Audio Output with THX TruStudio Pro
- 802.11b/g/n Wireless
- 7-in-1 Card Reader
- 720p HD Webcam
- USB 2.0 / 3.0 - 2 / 2
- HDMI & VGA Outputs
- Bluetooth 4.0
- 9 Cell Battery
- 2 Year Collect and Return Warranty
Was [£999.95] Inc. VAT
Only £899.99 inc VAT.
ORDER NOW
Asus TF600T-1B028R 10.1" Vivo Tab Windows RT Tablet - Windows 8 @ £559.99 inc VAT
The 10.1" Asus TF600T-1B028R Tablet is perfect for multimedia enjoyment. A stunning Super IPS+ display with 1366x768 resolution delivers superior visual clarity both indoors and out. The NVIDIA® Tegra® 3 quad-core processor offers super smooth performance while also delivering superb graphics performance.
Features:-
- Attractive Amethyst Gray Tablet
- 10.1" IPS With OGS Touch Panel
- 10-Finger Capacitive Touch Screen
- 1366x768 (WXGA) 600nits With Outdoor Readable Mode
- 3.7v*2 Li-Polymer Battery 6760mAH,(25W)
- Hi-Definition Audio Codec
- Built-In Stereo Speaker
- G-Sensor/ Light Sensor/E-Compass/ Gyroscope
- Front 2MP And Rear 8MP Cameras.
Specification:-
- Display size: 10.1"
- Resolution: 1366x768
- Screen type: Super-IPS+
- Processor: NVIDIA Tegra 3 1.30GHz Quad-Core
- Graphics: NVIDIA Tegra 3
- RAM: 2GB DDR3
- Storage: 64GB
- Camera: 8MP Rear, 2MP Front
- Connectivity: 1x Audio jack out, 1x Dock connector port, 1x Micro HDMI, 1x MicroSD
- Wireless connectivity: Bluetooth 4.0, GPS, WLAN 802.11 b/g/n
- Speakers: Asus SonicMaster Speakers
- Dimensions: 262.5 x 8.3 x 170.9 (WxHxD mm)
- Weight: 525g
- Battery life: 9hrs
- 1yr Warranty
Only £559.99 inc VAT.
ORDER NOW
OcUK Nebula 7" 8GB Tablet PC - Android ICS 4.0 /w Play Store @ £65.99 inc VAT
Conveniently compact and light enough for you to travel around, yet amazingly powerful, the OcUK Nebula tablet with a 7-inch display and a super speedy 1.2 GHz processor is perfect for web browsing at home, in the car or on a business trip. To make it just that little bit better, it even comes equipped with Adobe Flash support, multi-window browsing with pinch to zoom capability, and a clever quick look-up that allows you tap into Wikipedia, Youtube and other web resources as you wish.
Specification:-
- Dimensions 196 x 120 x 9.9 mm
- Processor Boxchip A10 Cortex A8 @ 1.2GHz
- Display 7" 16:9 with 800 x 480
- Touch Panel Capacitive Multi-touch
- Internal Memory DDRIII 1GB
- Onboard Flash Memory 8GB
- Wifi IEEE 802.11 b/g/n
- Camera: front 0.3 Mega Pixel
- HDMI: mini HDMI
- External Memory micro SD x 1 (support up to 32GB)
- USB: 2.0 mini USB x 1
- Audio out 3.5 mm
- Build-in Microphone Build-in Microphone x 1
- Battery: 3000mAh Rechargeable Li-Ion polymer @ 3.7V
- Power Adaptor 100~240V AC; 5V 2.0A DC
- Software & codec support
- Operating System Android 4.0
- Audio codec MP3 / WAV / WMA / AAC,AAC+
- Video codec FULL HD / MP4 / AVI(XVID,H.264,DIVX) / Flash lite 3.1 / 3GP
- Image formats JPG, GIF, PNG, BMP
- CE: Yes
- RoHS Declaration
- Ideal for streaming HD Video content to bigscreen TV (Mini HDMI to HDMI adapter required)
- USB OTG Cable included
- Micro SD Support (Upto 32GB)
- 1yr Warranty
Was [£79.99] Inc. VAT
Only £65.99 inc VAT.
ORDER NOW
Some mental deals here, so whether your buying for Christmas or just want to treat yourself, don't miss out on these epic deals. :D :D :D
25 Jun 2011
Aberdeen
Whoah!
Now Gibbo, if you want some more of my hard earned cash you have to do two things for me...speed up the refund for my 7970 and give MSI a kick up the bum sorting my Lightning out :D
DGM's look really tempting.
Permabanned
20 Oct 2012
No 660s? :(
I wouldnt go for a sandy i7 over an ivy i5 tbh.
My xmas gift is a 660-660Ti depending on the price ;)
Like mentioned above i need 2 refunds! one for my 7850 and one for my 7850+HDD its been nearly 2 week for the first one it says 5 working days???
Caporegime
12 Jul 2007
United Kingdom
I'll take one 2700K please at asking, £200.
Windows 8 new taskbar has opened my eyes that my 2500k is holding back my single 7970 in battlefield 3 64 player, seeing cpu usage around 90-95% and £200 + whatever I sell my 2500k for is just too good to refuse.
25 Jun 2011
Aberdeen
I doubt there will be much gaming difference between a 2500k and 2700k tbh? Really wouldnt bother if i was you.
8 Threads could be beneficial (in BF3) if he decides to drop another 7970 in at a later date :)
An absolute steal at £200 anyhow, 26/700K prices have been at a solid ~£240 since release.
3 Feb 2012
Peterborough
Really? Mine was in the 70's with a single 680... never that high.
Unless the new maps are more CPU intensive perhaps?
Caporegime
12 Jul 2007
United Kingdom
Battlefield 3 loves threads like JD loves buying GPU's.
No idea, maybe the 680 wasn't pushing as hard? I don't know. All I know is what I see. With bf3 64 man hectic action and a few other bits and bobs running including software to manage my bf3 server my cpu is being pushed to its limit. Another four threads will help ease the pain.
When I compared with a 2700k user he had better minimums on those 64 players maps.
Permabanned
20 Oct 2012
BF is getting old now, i know a lot of people still play it but i honestly am getting sick of it and i dont see the point in upgrading for 1 game for basically no difference lol.
£200 is nice for people with older quadcores but not for you really, specially if you wait and put the difference for the newer cpus next year?
How does an ivy i5 compare to a sandy i7 anyways? because the ivy is again much cheaper.
Caporegime
20 Jan 2005
Co Durham
Worth upgrading from my i7 950?
I'm a bit out of touch with current gen of cpus.
What will a 2700 overclock to? I run my current i7 at 4.4Ghz 24/7
3 Feb 2012
Peterborough
It was running at 99% that's all you can ask :D.
Yeah I think it'll help slightly and at that price it can't be sniffed at.
Enjoy.
Permabanned
20 Oct 2012
Would it be wise for me to get the i7 2700k and build a new machine now or just wait until may and see what happens? I dont really wanna go backwards but this could work out half the price.
