Hi there
En-route we have lots of Powerballs incoming, a truly awesome gift for Christmas or for some fun and antics between mates. Check them out including the all new Fusion Powerball.
Powerball Original 250Hz Blue @ £11.99 inc VAT
Designed to improve the wrist muscles, simply set the inner section spinning, rhythmic circular hand and wrist movements not only maintain the rotation, but also make it steadily faster. Increased in centrifugal forces make it harder to keep hold adding resistance to your wrist thus making you stronger.
Not only is this a great exercise for your wrist, it is also extremely addictive as it incorporates a high score system. The perfect instrument to gently rehabilitate lower forearm and wrist joints affected by carpal tunnel syndrome, repetitive strain injury, arthritis & previous breakage.
Only £11.99 inc VAT.
ORDER NOW
Powerball Neon Blue Pro @ £19.99 inc VAT
Introducing Powerball - one of the most unique and dynamic products available on the web today - 8 world records and counting!
Powerball is a dynamic and completely revolutionary new gyroscope that literally explodes with mind numbing torque and inertia once you activate its internal rotor.
It's about the same size as a tennis ball and weighs just a little more, but take a Powerball in your hand, set that rotor in motion with the cord provided (or use your finger when you get used to it) and you'll experience an extraordinary sensation:
Power ball slowly comes alive with gyroscopic force - a sublime yet pleasant resistance to your movement which is transmitted directly into your wrist and arms and which provides soothing, non impact rehabilitation at these lower speeds.
You want more?
Take it higher...much higher!
Bring your new Powerball up...up to 10,000rpm...the forces are now much stronger, much more vibrant. Higher! Take it to 12,000rpm...no, higher still...take it right up, thrashing and jerking as your arm and wrist try to control and calm it down, faster and faster it spins until you have it up to an unbelievable 15,000rpm at which point it's exerting almost 40lbs of pressure on your limbs and is travelling at nearly 250 revolutions per second - no batteries, no motor, just pure gyroscopic power - the fastest human propelled device ever created!
Features:-
- Unconditional Powerball Lifetime Warranty
- Includes LCD readout displaying RPM
- The highest quality Original Powerball Neon Blue
- Suitable for 14 years and older
Only £19.99 inc VAT.
ORDER NOW
Powerball Neon Red Pro @ £19.99 inc VAT
You want more?
Features:-
ORDER NOW
Powerball Neon Green Pro @ £19.99 inc VAT
You want more?
Features:-
ORDER NOW
Powerball 250Hz Techno @ £19.99 inc VAT
Designed to improve the hand, wrist and arm muscles, the new Powerball Techno is the most advanced version in the exciting Powerball product line up!
You set the inner flywheel spinning, using rhythmic circular hand and wrist movements to maintain the rotation and ultimately build the rotor speed - the faster you spin your new Techno, the greater the gyroscopic force that is generated from within the ball and the more difficult it becomes to hold - this all adds up to significant forearm burn and greatly improved strength in the wrists and hands.
Unlike some other models in the range which require an LCD counter to display the accumulated speed, you spin up this innovative gyroscope and watch as your score scrolls across the surface of the rotor, floating almost magically in a surreal red glow!
The rotor also displays an entrancing collection of 'firelines' as it spins, ranging from red to blue in colour and giving an a truly amazing effect depending on the speed at which it is revolving
ORDER NOW
Powerball Signature Pro Edition @ £23.99 inc VAT
Dynamic, exquisite, absolutely gorgeous! The extraordinary new Powerball Signature with its sapphire white light neon rotor revolving within a subtly smoked shell is truly a design classic and will exceed the very highest expectations of Powerball fans all over the world once they experience its silky smooth movement!
Put its rotor in motion and the ball instantly comes alive with Gyroscopic force - a sublime yet pleasant resistance to the movement of your wrist and hand and one which grows in its intensity as the speed of the rotor builds...faster and faster...up to a point where it is thrashing and jerking furiously, literally exploding with inertia and almost impossible to control!
This limited edition gyroscope has a top speed in excess of 16,000rpm and can generate over 40lbs of resistance on the hands and arms as it spins (which is quite extraordinary given that it is just the size of a tennis ball and weighs under 300grams!).
The new Signature is our premium Neon Powerball model and is supplied with an exclusive mini DVD providing you with exercise routines, three exciting Powerball film clips, starting tutorials plus the full suite of Akis World Speed records to really spin your mind!
An inbuilt computer on the outer shell offers you complete control over how fast (or slow!) to operate the ball and archives important data like the highest achieved speed (really important when challenging mates to a Powerball showdown...anywhere...anytime...Punk!
Also included as standard are two starting cords and a safety wrist strap to help ensure many years of smooth operation with this superlative product.
Only £23.99 inc VAT.
ORDER NOW
Powerball Fusion Pro @ £23.99 inc VAT
An entirely new dimension to NSd Power® ball, this latest addition to the RPM Sports™ range gives dynamic visual feedback on your scores! Start the rotor spinning and the ball glows a blazing red, quickly morphing into a deep purple overtone as you increase your speed...now bring the the revolutions higher, climbing above 8,000rpm, and see the rotor come alive with an explosion of crystal blue light, purely gorgeous!
An in-built digital counter allows you to monitor your progress and gives complete control over how fast (or slow!) you operate the ball, offering live feedback on your current and max speeds achieved (essential for our World Top 100 Scoreboards™....go on, you know you want to see your name there!
The exquisite design and build quality of the superlative new Fusion guarantees you a pleasant and silky smooth operation all the way to 16,000rpm and above. We guarantee that this latest addition to the Powerball range will greatly exceed your expectations and become a firm favourite around the globe!
ORDER NOW
These are epic fun, I personally recommend the Pro models simply for the speed counter for the competitive fun.
Stock is due to land this Friday, so well in time for Christmas.
