Caporegime
- 18 Sep 2009
- Dormanstown.
Rich, we're talking MHZ overclock here, like 50MHZ if you're lucky.
Sure, the cores are very overclockable, there's just no way to do it
But I don't see the board as bad, I know there's some common problems with that series of boards (They won't work in dual channel) having had the issue myself on a like Z68 board, which I've also seen a thread with the Z77 board suffering the same issue, not that I wouldn't buy it, because I would.
That said, I'd go for a B-Grade Z68 board with an entry level i5 as opposed the i3 and the Z77 board, you can still get your PCI-E 3.0, as long as it's an Ivy you've chucked in.
