- 19 Oct 2002
- Shakespeare’s County
Especially when they are doing the same speed for miles and miles with no braking.
What would you say is proper regenerative brakin as opposed to how it's done in F1?
Recovering much more energy by using the electricity generation as the primary braking mechanism. (With friction brakes as a fall back for safety reasons only, eventually being phased out altogether once people have confidence in the system)
Releasing the recovered energy as an alternative to burning fuel rather than just as a "Power boost".
KERS is doing a lot of damage to peoples perception of what regenerative braking can do for road cars.
I'd be more impressed if someone could harness the heat loss from engines. That's the real energy loss.
Toyota got there first with the Prius. Regenerative braking, but theirs goes a step further and powers some electric motors.
No they didn't.
GM with the EV1. Easy to do when you have a high voltage power system.
I meant highly successful mass produced car you see every day.
Which the mk1 Prius most certainly wasn't.
Use the heat to boil water, use the steam to turn a turbine, use the turbine to turn stuff!
I shall call it the boiling water-turbine-turner engine!
