Found this thread, saying the same thing and i new Nvidia cards didnt suffer from this
There seems to be a fix with the 60Hz and FPS limit but i dunno if im doing it correct as im still getting bad stuttering?
http://forums.guru3d.com/showthread.php?p=4217669
Get the latest version of Radeonpro here (1.1.1.0).
http://www.radeonpro.info/en-US/Downloads/Preview.aspx
If you want download the manual and read other forum posts here.
http://forums.guru3d.com/showthread.php?t=322031
make sure you set the profile to the Tesv.exe not the Skyrimlauncher.exe. Using the Tweaks tab in Radeonpro tick the option to use "lock framerate to monitors refresh rate", or set a dynamic FPS lock of 60 (or lower if need be). I just did this myself and the game runs smooth for me. If you are still stuck I can upload some screenshots of my settings.
Good luck.
