*** The OcUK Ultima 10.1 Thread ***
There's nothing wrong with Chrome, you guys just assigned a browser that doesn't support flash to try and play a flash video :p
I solved it by installing Firefox which now gives me the browser choice window.
[Edit] Firefox doesn't work either.
Clearing data on Chrome won't change it as a default application. Scroll down a bit more to where it says Launch by Default.
I'll have a look for this anyway.
[Edit] Cleared Chrome 'Launch by Default'
Ha you got there in the end mate..;)
Eventually! :o:D
Strange as when I looked earlier I couldn't access the Launch by Default setting. :confused:
How did you get Firefox to work with iplayer, as mine gives me the same message as Chrome?
Stock browser is fine.
Well I tried all 3 including Dolphin and they all worked, then I deleted Firefox and have just left Dolphin and the stock browser on the Tablet, I disabled Chrome when I first got the Tablet yesterday, was one of the first things I did!
Mine arrived this afternoon and first impressions are excellent! :D
Only real weaknesses I can see is the cameras (not fussed) and the sound seems a little quiet!
Just search for Merlin using the search bar on the top and will give you these options..:D
http://i112.photobucket.com/albums/n165/crazylegsdude/Screenshot_2012-12-28-19-39-45_zpsd11fb0cb.png[IMG][/QUOTE]
I tried searching but don't get the same choice as you. Is this in the stock browser?
I'm not getting any such options :(
So far I have been impressed with this tablet for the few hours I have been using it.
Gripes so far are;
1) Back light bleed bottom left had corner
2) 2 x Dead/Stuck pixels and/or dirt (they are different in size)
3) Noise interference when using headphones
How are people finding the battery life? I have run mine down and then fully recharged but it seems a little on the short side.
If you have the option in your browser settings for "Always request desktop site" you don't need iplayer just go to bbc iplayer and pick a HD program..Done.
But make sure it's over wireless not 3g.
Thanks, got the HD options now.
Using the Dolphin browser menu select > More > Settings > User Agent > Select Desktop
[Edit] It prompts you to install flash. :mad:
Using the stock browser is no problem, just select 'Resquest desktop site' option from the menu which is selected from the top right corner of the browser. :cool:
Next F1 season you can have the main race on your tv and the car cams on the pad ;)
Having probs here, four times today it has just given up and closed down, resetting then takes ages and normally needs plugged in.
I've done a factory reset which came back in German, hopefully it was something I installed rather than a faulty tab. I'll use it for a while more but if it goes again I'll have to return it, that would be a sore one as it really is a rather nice unit.
Two more times but not while plugged in, battery says 56% left but maybe it fibs. Going to charge it and see.........ahhhhh whyyyyyyyyy.
