- 22 Sep 2007
- Abingdon
You wont get a brand new replacement for an outlet model.
If that's the case I'll be getting my £2877 back then, can't be doing with getting another faulty machine
I had a brand new replacement for an outlet laptop last year. I bought an M18x R1 which had dual GTX460M graphics cards, but the SLI did not work. After 3 repair attempts and some email/twitter harassment from me they eventually replaced it with a new one. It wasn't the same spec though; the replacement just had a single GTX560M.
I want to join in with the failure of getting an Alienware but school...
If that's the case I'll be getting my £2877 back then, can't be doing with getting another faulty machine![]()
Just ordered an M18X, can anyone help with the following.
I am assuming it has SATA III ports, if so how many?
What are the max capacity drives in each slot it can handle?
What RAID options does the board support?
Ordered this spec:
Congratulations! Your system is ready to be built.
Included in your system:
COLOUR CHOICE Alienware M18x Nebula Red - Anodized Aluminum edit
PROCESSOR 3rd Generation Intel® Core™ i7-3940XM (8MB Cache, up to 3.9GHz w/ Turbo Boost 2.0) edit
OPERATING SYSTEM English Windows® 7 Ultimate (64 BIT) edit
GRAPHICS CARD Dual 2GB GDDR5 NVIDIA® GeForce® GTX 680M SLI™ edit
MEMORY 16385 MB (4x4GB) 1866MHz DDR3 Dual Channel edit
HARD DRIVE 500GB 7,200rpm SATA 3Gb/s HDD edit
LCD 18.4" WideFHD (1920 x 1080) WLED LCD edit
OPTICAL DRIVE BluRay Combo (Blu-ray read only, DVD, CD read & write) edit
WIRELESS CONNECTIVITY Killer Wireless-N 1103 a/g/n 3x3 MIMO with Bluetooth 4.0 edit
PRIMARY BATTERY Primary 12-cell 96W/HR LI-ION
Thanks James
Nice spec!
It has two sata3 and one sata2 connector so 3 2.5" HDD's in total. Plus one mSata port which is sata2 speed. Raid is 0 or 1.
I7 3630, 16Gb Ram, 2GB 680m and Blu-Ray for £1200 inc.
Gutting
Will no doubt end up on eBay
going by your sig, you've got an Alienware already?
Just phoned dell up, they reacon they don't offer anywhere near the 20percent discount off I think I read earlier in this thread, they knocked 100 off a 1500 laptop and said that's the best they can do
Might need to try again or I might need to go down Clevo route or look elsewhere
I ordered mine yesterday, there is no possible way I can pick one up off the outlet with my school times for about a month which is a problem as I kinda need a pc now'ish
So the deal is, you will not get much off a base spec laptop. bump the specs up a lot and you'll get closer to that 20% I mentioned. Secondly, you wont get it though random dell man. You will have to search another forum to get the person who can offer you a large discount (my sig I got 13% off)
