Perth has a "local Flu"
There is an extremely good chance you will get it.
Just letting you know it aint all rosy.
Have fun and stay away from Northbridge !!
[Edit]
No one mentioned Yanchep ?
Scarborough was our fave beach. Be aware of City beach. From the shore the sea immediately gets quite deep. That's not the problem, it's the very strong side rip. What happens is you enter full of enthusiasm and strength and swim out where the sea then goes up onto a LARGE sandbar which is knee deep. You then wade out into the deeper stuff (you can see the colour change to a deeper blue) and doing yer surfin.
When you've had enough and are genuinely knackered you then want to go back to shore..... But... You forget that deep bit with the VERY strong side rip next to the beach.
~ <-- Your towel on the beach..... --------------------------------------------------------------------------------------------------------------------------------------> where you make shore !! (other way round actually ie: Northerly current)
Cottesloe is where the Bogans hang out.
How do I know this stuff ?
Clue.. (Early 70's)
And.. Funny School memory (Fourth post down)
http://archive.atomicmpc.com.au/forums.asp?s=1&c=1&t=103023&p=40
Also worth going to the lookouts at Lesmurdie Falls.. And checking out the Girlies at Kalamunda Pool / Bibra Lakes.
Drag Racing at Ravenswood
[Edit]
Clue.. (Early 70's)
