I recently bought a Corsair H80i kit and the stock fans that came with it are horendously loud, worse than Heathrow.
Stock corsair fans arent great from what ive heard. If theese are indeed the same fan as the se2000's. Theyll be very good. But id want to be running them off a fan controller.
Does the voltage adaptor came with it?
Product description says OEM version means that this fan comes without packaging or accessories.
So no, probably not![]()
Tell you what, I have a bunch of 7v and 5v adaptors that I'll never use.
Trust me your details and I'll send you a couple of each in the post if you like?
