Try with other sata cables as well, to rule those out
I forgot to ask how full is the drive? that will affect overall performance
usually a secure erase restores performance
I seem to be getting similar scores to your M4 with mine:/ it's not even really that old either probably coming up to a year now. Don't think it's a good sign and it's my OS drive as well D:
Edit:
Actually mine are worse. (probably due to the partition alignment which I should have fixed before a fresh windows install :/)
use paragon alignment tool,it fixes it without reinstall
Edit:
That 31k bad would defo have a bad effect on your score.
1
I assume you're not using Win7? Win XP screws up alignment, whereas from what I've seen Win7 never does. As an aside if you have Vista that from what I've seen does give good alighment, but if you are using XP after creating the partition & formating the main drive, don't format again if you do install XP
2
You can do realignment with other free software from Linux, again it may be Gparted but my memory I'm afraid lets me down. BTW I have used it successfully, I'll try to find out for Defo what this software is & post it in here Morning or afternoon side, much later on today. Thurs.
Just spent hours trying to realign my partition using Gpart to no avail D:
I'd had win7 for 12 months in my desk but didn't like it, used to it now tho.
(I hope) Well, they are for me anyway.
TBH Ollie I found it took me ages to get my head round it & only used it on one occasion after which I thought I'm not going that route again & finally made the move to use Win7 permanently,I'd had win7 for 12 months in my desk but didn't like it, used to it now tho.
Sorry, I digress.
If I were you I'd re-install Win 7 again, the bit thats important arrives when Win 7 is ready to format the drive, you need to go in to the options menu (I think) & delete all prior partitions & allow Win 7 to create a new partitions ((there will be two) the smaller of which (100mb-ish) is used by the system) don't change the size of the partitions that 7 makes, the drive will then be perfectly aligned.(I hope) Well, they are for me anyway.
PS & Important I'm a silver old surfer, and may have explained the above badly, please feel free to add or make required corrections![]()
Theres meant to be a way to bounce it around so it starts at 64 instead of 63 :/
I'm lucky (maybe) I've got all day to faff with the PC I just wish I'd got a better understanding of all the whys, & why nots.
I'm sorry Ollie, the 64 instead of 63 is a bit above me.
old HDD's started on 63 and SSD's start on 64. I'll figure something out
Might get a new SSD when I can afford to
