**** Official Titan owners thread. ****
3 Jun 2012
Greg... I would suggest going coloured tube and distilled water with a silver coil when you redo loop to include the titans... Nothing to clog anything up or stain anything.
6 Aug 2009
Wales
Nice looking rig gregster especially with two of those beasts in there!
But you really should dust that rig down man:D
Slightly off topic but the current coolant your using.. it wouldn't happen to be Mayhems Aurora Tharsis red would it?
The reason i ask is because i'm using it, but it's only been a week and it's already lost of of it's sparkle, so like you i'm thinking about getting coloured tubing next week.
Caporegime
24 Sep 2008
Essex innit!
Ok,ok I will give it a good de-dust :p
Just done 2 bench tests in games and Crysis 3!!! Ohhhh Mannnnn, killer :(
Frames, Time (ms), Min, Max, Avg
7729, 300000, 16, 35, 25.763
First mission (in the rain on the ships) and everything maxed with 8*MSAA
14 Nov 2012
Will an 850w psu handle
x2 Asus GeForce GTX Titan 6144MB GDDR5 PCI-Express Graphics Card
Intel Core i7-3820 3.60GHz (Sandybridge-E) Socket LGA2011 Processor - Retail
Gigabyte X79-UP4 Intel X79 (Socket 2011) DDR3 Motherboard
NZXT Phantom Enthusiast USB3.0 Full Tower Case - Red/White
Samsung 120GB SSD 840 SATA 6Gb/s Basic - (MZ-7TD120BW)
GeIL Enhance Corsa 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Quad Channel Kit (GEC316GB1600C9QC)
14 Nov 2012
Caporegime
24 Sep 2008
Essex innit!
Yes :)
That Aurora is more for showcasing and not permanent bud. It can clog quite badly in a short period of time. I am using Pastel Mayhems, which has 12-18 months before needing to be changed.
27 Jan 2003
Chesterfield, UK
Greg anychance you could recommend a 850w psu for 100£ or less bro
Don't skimp on a PSU especially one where your potentially drawing this sort of load. Cheap units have a tendancy to take your equipment out or worse burn your house to the ground. If you stick to Seasonic / Corsair you won't go far wrong.
Work out your max load first and go from there.
6 Aug 2009
Wales
Yes :)
Thanks for advice pal,
Looks like i'll be swapping this stuff out for some pastel stuff then next week.....now.....what colours.....hmmmmm.
5 Sep 2010
7729, 300000, 16, 35, 25.763.
I read one review of gpu performance tests with Crysis 3, they named it the system killer, and this was only on High settings with 4xmsaa medium :eek:.
Titan SLI @1920x1080 had very nice framerates (95fps) but @5,760x1080 was just under 40fps.
