Indeed. I deal with profitability not probability.
It's a long time since I did a Statistics GCSE and I just wanted to check. I was correct after all.
Ha. No wonder our economy is going down the toilet.
KERBLAMMO!!
It's unlikely.
[FnG]magnolia;24132655 said:Probably.
Certainly.
I deal with events that have already happened.
If there is only one winning ticket drawn, then 1:5 and 5:25 are the same.
If there is more than one winning ticket being drawn, then it is better to have 5:25 rather than 1:5.
Yeah cos doing the maths on stuff that's happened is different than doing the maths on stuff that hasn't happened yet.
[FnG]magnolia;24133271 said:I have one sandwich and I cut it in two.
! WHERE DID THE OTHER SANDWICH COME FROM !
When dealing with probablility, which we are, then yes they are different. Insofar as events which have happened are certainties and probability doesn't come into it.
assuming that only 1 ticket is drawn in the raffle then the chance is equal.. if you have multiple draws then the chance is not the same to win across all draws.
The chances of winning are 50%.
1 in 5, 5 in 25, etc, are irrelevant, you'll either win or you won't.![]()
Are you sure about that?
Example:
3 tickets are drawn in a raffle, what is the probability that you will have 1 winning ticket if:
a) there are 5 possible tickets and you have 1 ticket
b) there are 25 possible tickets and you have 5 tickets
Answers:
a) Odds of getting 1st winning ticket: 1/5
Odds of getting 2nd winning ticket: 1/4
Odds of getting 3rd winning ticket: 1/3
Total odds: (1/5)+(1/4)+(1/3) = 47/60 = 0.7833r
b) Odds of getting 1st winning ticket: 5/25
Odds of getting 2nd winning ticket: 5/24
Odds of getting 3rd winning ticket: 5/23
Total odds: (5/25)+(5/24)+(5/23) = 1727/2760 = 0.6257
It's future, present, or past tense, a mixture of all, some or none is irrelevant.
1/5 = 5/25
It's maths. You're confused.
What if I asked you, "I bought 5 raffle tickets yesterday, there were a total of 25 tickets, what was the probability that I won?". Would you be able to solve that?
Martytoon said:But do you not have to consider the probability of profitability?
