The stock cooler on my XFX 7970 Ghz edition performs poorly and noisily. I'd like to replace it with an aftermarket option. But which one?
My system is an air-cooled Asus P5Q-Pro in a Fractal Design R4. I am constrained by the space available.
The Arctic Xtreme, at a reported 305mm overall length is too long. Anything longer than about 290mm will impact the front drive bays, which are in use and cannot be removed.
The Prolimatech MK-26 looks almost like it could be the one, but it must not take up more than 3 slots overall including fans because my second PCI-e slot is occupied by my PERC-4 SCSI RAID card. Asus advises that when a single graphics card is used that it should go in the upper PCI-e slot, so I can't swap them around to create more space.
Is it possible for the Prolimatech MK-26 to be a 3-slot solution with fans? How many slots would it take up if I mounted those 12mm slim Scythe fans on it? What about mounting a fan perpendicular to it blowing across and towards the back. Would that work? It would have the advantage of keeping the hot air from the card away from the stack of four 15K SCSI drives that I've got at the front...
Are there any other options I haven't thought of? How about a cooler designed for another card with an aftermarket copper shim off ebay (the 7970 GPU is recessed below the cooler mount frame). From the pictures I can see of the Prolimatech, it must be using a shim to mount on the 7970 because it does not have the required 'bump' on the base where it meets the GPU so using a shim can't be too bad.
Any advice would be appreciated.
- Andy
- Andy
. 3 slots is the absolute max for me I'm afraid. Thanks for looking though.
