Crossfire 7970's poor crysis 3 performance!
I've not played Crysis 3 yet, other than 10 mins at the start...i think i was getting 60+fps with everything turned up to 11 using CF7970s @1080.
If you give me a couple of hours to put my rig back together i can run tests using both single card, CF and tri-fire. Pretty sure i have it installed on one of my SSDs.
Cheers, no rush mind!
Gonna benchmark it in a bit and post my results soon.
I'm not far enough into Crysis 3 to compare here i'm afraid. What sort of scores are you getting in Unigine Valley? I would be expecting >3500 with your setup (check out the Unigine thread for settings)
This is what I got for a short segment around the start of the game completely maxed out, playable but by no means smooth, this is with 7970 CF 1010/1375 & 3820 @ 4.75ghz ddr2000 C8.
Frames, Time (ms), Min, Max, Avg
8487, 175594, 30, 103, 48.333
If i see you using clocks as low as that again then we'll be having words. :p
If you want some RadeonPro suggestions just holla! :cool:
Tbh the game doesn't appeal to me that much.
Only at stock when the power isn't needed, I don't quite need 1250/1800 to drive many games :p
Can't argue with that i guess.
You down for Dirt Showdown this thursday night, 8pm onward till 10pm? Gonna see if i can get tommy and scotty on board. Either way should be at least 4-8 of us.
Sign up here to get the TS details. - http://www.cq247.co.uk/
