Good find Kaap. I had noticed something was fishy (assuming it was just me) with pushing another 8Mhz here and there and still getting the same results. Good spot![]()
+160 ish has been the highest I can achieve. I expect a little higher under water but it would have been better to do this in the winter. A chiller one day perhaps...
I still have not got mine setup yet, I must do it next week.
I spoke with Tones about condensation and he will be using Air Conditioning. What will you be using? I have seen some setups with foam around the pipes and that would have to be the way I go.
Bit annoyed to see a lot of the 780s clocking a lot higher than either of my Titans. I thought the binning process would have stopped something like that happening?
They should clock a little bit higher, with one less SMX than a Titan the GTX 780 will produce less heat and enable a slightly better overclock.
Can any titan or 780 sli user who owns serious sam 3 load it up and have a quick go please? I want to know what your gpu usage is like, plus if it tears or not? Mines a right mess on it. Runs at around 75fps, like its got some weird limiter on it, with both gpus sat at around 40% and not even in 3d clocks most of the time. Power management is set to performance, using lastest whql drivers (320.18s). Really weird issue.
Didn't sit at full clocks (they were around 900mhz) but I was getting around 250-300fps & tearing wasn't anything out of the ordinary.
Titan sli with 320.18
