Do you have root?
If so just need to install Aosp installer from the play store. And then quick ics will work.
What's the best root out there for an s4?
Also can someone point me in the direction of an idiots guide to rootingand what are the main benefits of rooting?
Model: GT-I9505 (4.2.2)
PDA: XXUBMEA
PHONE: XXUBMEA
CSC: OXABMEA (MultiCSC - 8 codes)
Kernel: 3.4.0-768421 (30.05)
Build Date: 29.05.2013
Changelist: 768421
Pre-Rooted ROM: Downloads: <<< Hotfile >>> or <<< Android Host >>>
Easy way to root is to flash a pre-rooted rom from here - MEA is one of the latest, so you'll root and update your rom at the same time.
http://forum.xda-developers.com/showthread.php?t=2250824
Pick:
choose the below file
Use the Android host as its faster to download.
Once you have downloaded the ROM, put your phone in download mode and open Odin and flash the ROM as PDA.
Watch this video on how to use odin:
http://www.youtube.com/watch?v=vlsO5o_-CI8
Benefits of rooting:
- Proper adblocker
- Use extra settings in apps that need root access e.g. Nova launcher, hide time on desktop status bar
- Delete system apps (bloat)
- Make full app backups with games saves, app settings etc using Titanium Backup.
Next step is to install a custom recovery like CWM or TWRP. This enables you to install custom roms, tweaks, system wide themes etc.
You can also use it to make a backup image of your whole rom and settings.
Youtube is your friend - watch a load of videos.![]()
Are there any supported apps for moving apps to SD card without being rooted?
When the new firmware arrives it will also move to SD.
The standard apps to SD is a pointless feature though isn't it? The main problem is big game data which it doesn't move. You need root for that.
I think I need to just bite the bullet & root then!
Has the Lag been addressed with the latest update?
I had the S4 but returned it due to the lag when switching screens etc
Root is so easy it's rude not to![]()
