- 9 Oct 2011
Hi all,
I'm going to be purchasing my first SSD for my most recent build. I'm hoping to have a HDD in there as well with most of my files on, and I will be putting the OS on to an SSD.
1. What sort of size SSD is required for this? Something around 128GB or would you recommend doubling that? Can you also recommend some good quality SSDs of that size?
2. Before installing the OS, do I need to do anything to set up the SSD. I've heard something about TRIM but I don't know anything about it. If it helps I have an asus p8z77-I deluxe. Do i need to make any changes in the bios?
Thanks in advance!
Thanks in advance!
