Another office workhorse
29 Aug 2011
Hi everyone,
I'm looking to build a work PC for normal office duties plus graphics work (CorelDraw suite). I will connect two monitors, but will rely initially on the built-in graphics capabilities. The intention is to end up with a "snappy" system and will be running VirtualBox (hence the 16Gb RAM). Overclocking is not an initial consideration, but I can upgrade the cooling later.
Should I change anything?
Thanks!
YOUR BASKET
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - Retail £197.99
1 x Microsoft Windows 7 Professional SP1 64-Bit - OEM (FQC-04649) £119.99
1 x Patriot Viper "Black Mamba" Generation 3 16GB (2x8GB) DDR3 PC3-17000C11 2133MHz Dual Channel Kit (PV316G213C1K) £119.99
1 x Gigabyte Z87-HD3 Intel Z87 (Socket 1150) DDR3 ATX Motherboard £99.95
1 x Adata Premier Pro SP900 128GB 2.5" SATA 6Gb/s Solid State Hard Drive (ASP900S3-128GM-C) £89.99
1 x Western Digital Caviar Green 2TB SATA 6Gb/s 64MB Cache - OEM (WD20EZRX) HDD £75.95
1 x OCZ CoreXtreme 500w '80 Plus' Power Supply £34.99
1 x BitFenix Merc Beta Gaming Case - Black £32.99
1 x Akasa USB 3.0 SuperSpeed Memory Card Reader (Internal header) (AK-ICR-14) £17.99
1 x OcUK 20x DVD±RW SATA ReWriter (Black) - OEM £16.99
Total : £820.91 (includes shipping : £11.75).
