Can you buy Corsair PSU leads separate?
16 Mar 2012
Chelmsford,Essex,UK
Hi my friend needs to replace the sata power lead on his TX650M it's the cheap lead as its semi-modular PSU. Anyway at the moment we just used an extension from a molex but he wants the proper lead!
The problem Is Corsair only seems to sell the leads in bundles the only one I can see separate are the 24 pin motherboard leads.
So if anyone can help thanks in advance
Well after a look on the auction site I have found 1 for just under a tenner.
Thanks
Did you try asking Corsair? caused I actually ask Corsair for a replacement cable a while back as I lost mine for an HX620 an they send me one, but it took like a month to arrived.
If your in a hurry to get one it's probably faster just to buy one from the auction site.
I'm going to agree with the above, just remembered that I broke a clasp of my NZXT Phantom case (it was the bit that slides up and down on the back of the case to hold on the side panel), and contacted NZXT themselves, were very helpful and sent of a replacement (this was just over a year ago now), worth a try contacting Corsair themselves (even though you have it sorted already lol)
Thanks
borley - If you only need the SATA cable, then I'd suggest that you submit a ticket and describe the cable that you need. Once you have the ticket #, post it here and I can help you out speed up the process.
