If we just wanted to use the SSD for windows 7 professional 64 bit wouldn't 250Gb be too high a capacity? Also on a 4 RAM slot Motherboard where we want 16Gb of RAM is it better to have 4 x 4Gb or 2 x 8Gb sticks?
What is the downside of 16Gb compared to 8Gb of RAM apart from the higher price?
Also on a 4 RAM slot Motherboard is it better to have 4 x 4Gb or 2 x 8Gb sticks?
If you can afford the extra ram in your build then go for it, but generally 8gb is fine, I run 16gb and probably wont go for anything less
See my reply above (2nd sentence)
so make sure that you get the fastest RAM you can to get the most out of it, faster RAM will make the system feel more responsive and help when chugging thought demanding task's like 3D Studio Max renders.We have now decided on 2 x 8Gb sticks installed on a Asus Z87 MAXIMUS VI EXTREME with the Intel Core i7-4770K 3.50GHz bundle with the H100i.
I see that the Samsung EVO drives are on pre-order. When are they avaliable to buy?
given that you are not using sub zero temps most higher end z87 will overclock about the same due the heat produced by the CPU so why not save some cash?Generally I'd go for 1 card. However your budget is sufficiently big that you're beyond the limits of good price/performance single cards so it'll be reasonable to switch to two.1. Are 2 medium priced graphics cards running in crossfire better than using just one better card?
I favour AMD cards at the moment but its down to personal preference mostly. No strict reason to pick one or the other. Depending on what games or whatever the multi-screen support varies.2. I always used ATI (AMD) graphics cards, why have most people suggested nVidia? In the past ATI cards were good for using 2 screens as an extended desktop and I could never manage to set up 2 screens using an nVidia card.
Windows, apps, games - SSDs rock. Raid 0 conventional drives is totally eclipsed by it. Not that much extra value to be had from raid 0'ing SSDs in normal desktops.3. Most of your options are including the Samsung SSD and only one other HDD. At the momemt on my "antique" system I am using 2 identical drives running in Raid 0. Does nobody bother with this any longer?
Are you loading windows onto the SSD and everything else on the conventional single HDD?
I'd pick 2*8GB sticks - though to be honest I'd probably just go for 8GB in 2*4GB sticks.4. On a 4 RAM slot Motherboard where we want 16Gb of RAM is it better to have 4 x 4Gb or 2 x 8Gb sticks?
Keep your thoughts coming,
in that price bracket Giga OC, ASUS Hero or MVIG are the boards of choice.
