Diffused lighting - built in wardrobe
Man of Honour
17 Oct 2002
Ottakring, Vienna.
I'm in the process of designing some built in over bed wardrobes and units for the new house, and I want to include some lighting. Lighting inside the wardrobe that will illuminate both the inside of the wardrobe and also function as a gentle bedside light.
At this stage I'm considering either fluorescent tubes hidden in a void inside the wardrobe or possibly even 12v LED strips running off a house alarm battery (done this before)
My struggle is diffusing the light from either source. The diffuse steps would need to be reasonably long and thin, unless I come up with a different design which is possible.
Has anyone got any suggestions for a material to diffuse the lights without costing the earth?
Man of Honour
OP
17 Oct 2002
Ottakring, Vienna.
How does this work? I can't see the fridge light when the door is shut :confused:
Fluorescents come with diffusers?
It's a wardrobe, not a fridge. Imagine a wardrobe, with a light in it. Imagine you want to see that light from the outside as well as when the door is open. So, I'll be cutting a hole in the side of the wardrobe which will need some form of diffuser to fill that hole, or it will look horrendous.....
Permabanned
18 May 2006
Ah, vital information ...totally left out :p
Japanese paper wall type thing maybe?
If you want something pro then acid etch a piece of glass and match the trim to the wardrobe.
Diffuse adhesive film is cheaper though.
