- 24 Aug 2006
- Gibraltar
Hello guys quick question. I work at lxgb and would like to know what game + addons would i need to use my airport in game? Thanks.
Flight Simulator X and Aerosoft's Gibraltar X should do you good.
Thanks for the quick reply. Is it possible to add/ input acutal weather value aswell as it what makes this airfield appealling
GRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR !!! just got a OOM![]()
Just as I was touching down!!! first time ever at Gatwick!
There are a number of weather packages out there.
REX
Opusfsx
Active Sky.
I've used all 3 and find Opus the most accurate. I use Rex for the cloud textures etc. They do fantastic textures.
I was reading about Opus FX and for £30 it does loads...
However, has anybody got it installed and running across a network?
If I've read correctly, you need an FSX install on client and server to make use of 'Live Camera Views'. Is this how it works?
Maybe your PC thought 'he we go again' and had already allocated memory for a Go Around? When your tyres delicately kissed the tarmac, it was memory overload.![]()
I have just installed FSX again with VFR real scenery for South East England, but I think the scenery looks a bit rubbish compared to some screenshots in here. Is there a better scenery pack for East/South East England? Or maybe I have not set it up right
REX
Opusfsx
Active Sky.
and the best one isn't even on your list
If you want the most accurate aloft winds then FSGRW is the one to get. It also does a much better job at weather depiction and the only one of all four weather engines to do a half decent job at fog generation (with stratus clouds).
Nice Photos, what mods you using again?
Not heard too much about FSGW so cant comment. Opus is a fantastic . The Dev's are constantly working on it. It improves every week.
Yes. I'm back and ready whenever you are.
