- 14 Mar 2011
Unplug it from mains and then press and hold the power button on the case for a few seconds. It'll discharge all the caps in the system.
Ah there we go, makes sense Good to know
Any one tried playing games on the N54L. My housemate is keen to get Fifa 14 on; on paper it looks fine but wondered if it differs in the real world.
1GB 6450, 8GB RAM and an SSD.
I used to have the Sapphire 7750 in an old PC and it was a pretty decent card considering it's size and power requirements (or lack there of)
Quick question to people running FreeNAS; are you using UFS or ZFS to manage your volumes? I don't want to setup raid in fear of it failing and taking out the whole array but at the same time I dont want parity as the data is media and aint that important.
ZFS seems to be primarily raid but all the plugins and that are tailored for it.
To take slightly off topic has anyone here upgraded they're freenas install to 9.1.1 yet. I tried yesterday and have come across some issues.
Have tried looking through the thread but clearly my search powers are weak!
What is needed to add a hard drive to the top bay guys? Many thanks
Huh huh huh, you have much to learn of searching my friend
I've not gone there myself but afaik from the rest of the thread you will need some sort of a 5.25 to 2.5 or 3.5 adapter for the optical bay (for an SSD you could get away without one and just tape it somewhere)... Then you can connect it to either the internal single-SATA port which is meant for an optical drive, OR using an eSATA to SATA connecter plugged into the rear eSATA port and looped back into the case... To make either of these ports run at full speed you need to flash the BIOS to a modded one which enables AHCI on both of them
Can anyone link me to the custom HP ESXi image please? for the N54L.....
ta
