770 gtx issue (worried man )
2 Nov 2013
Hi there , I bought and built a new system yesterday and installed the KFA2 GeForce GTX 770 LTD OC 2048MB card in my system .
I loaded windows on
downloaded the drivers for the card
Installed coretemp
Installed 3dmark ( old one)
I then ran 3d mark and while it was loading the very first test the screen went black . I restarted the system and the graphics card fans were running at 100% but no signal on my monitor . Since then the fans dont run at full speed but I still cant get a signal from the card . The card is still getting power and the system is still booting as keyboard lights ect come on . I have also tried an old 5 series ATI card and it runs fine . So is my card dead ? , and how does this happen as I only used it for around 1 hour in total
Btw the 3dmark was 05 or 06 if this makes a difference .
:mad:
Cheers
Alan
my 290x did the same thing so i rma'd it. Worth testing it in another machine if at all possible just to double check but sounds like a faulty card
Not got another machine unfortunately . Does anyone know how long the rma process will take as am off work just now with a bad back and was hoping to keep myself entertained with some good gaming .
Ok . Thanks for your help folks , I dont feel to bad now . Just wish I had the card running as the 3 fans were keeping my case incredibly chilly lol
yeah i had a 290x....... had to return it and none in stock at the moment so had to wait :( itchy buying finger just ordered loads of watercooling things while i wait. It really does suck when something doesn't work you just ordered but hey that's life
