Just read that virgin will be upping my download speed next year to 150Mbit - anyone know the speed of steams maxed throughput.
Long as you set the server to the right one you will get fast speeds.(depending its not peak time)
Only UK options in 'Downloads' on mine are London and Manchester. Anyone found the quickest one to set it to?
The vast majority of my Virgin traffic leaves the virgin network at Manchester if it helps. I get marginally better speeds out of Manc than London on 60MBit but it's splitting hairs really.Only UK options in 'Downloads' on mine are London and Manchester. Anyone found the quickest one to set it to?
You guys do realise that the steam download speeds are in MB/s, while your internet connection speed is usually in Mb/s dont you? 8Mb/s = 1MB/s (little b = bits, big B = bytes). Pretty much everyone seems to be maxing out their connection when you take that into account
