- 25 Aug 2013
Good day chaps,
So around a year and a half ago I bought the Acer Aspire V3-571G to use for school work and play some relatively good games. At first it was performing great, above 40 FPS in games such as Bioshock Infinite and Fallout 3 which are quite big games to run and to be running them above 30 FPS, on medium graphics, is great. After having a little break from PC gaming, but still using the laptop for work and such, I found myself to be having issues. It could not do any better than 10 FPS. I shall post the important specs below:
Because it's a laptop I don't know the motherboard or power supply but I researched the components posted above and found out that they are supposed to be "high-end" which at first they were performing like they are. But now, they perform like they were made in 2002.
I have posted here to ask the question, does anyone know what has happened? Obviously I have not given you enough information to know EVERYTHING, so of course, ask some questions. But I was just wondering, have I clogged the machine up with junk that has cause it to run slower? Does it just slow down after I've used it many times?
I'm not completely computer illiterate but at the same time, I'm not a genius so if you can help, please try and explain it as if you were talking to a child
Any help is appreciated and Thank You if you have read through this
Martin.
- CPU: Intel Core i5-3210M 2.5GHz (with Turbo Boost up to 3.1GHz)
- GPU: NVIDIA GeForce GT 630M with 2GB Dedicated VRAM
- RAM: 8GB
- HDD: 750GB
Martin.
