<<<<< BLACK FRIDAY DEALS: NVIDIA GRAPHICS CARDS!! >>>>>
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Right the savings can't be quite as crazy on NVIDIA sorry guys, but what we can try to do is have the best price in the UK, so here goes:-
Asus GeForce GTX 780Ti 3072MB GDDR5 PCI-Express Graphics Card @ £539.99 inc VAT
The ASUS GTX 780 Ti is a graphics card powered by the brand-new GeForce® GTX 780 Ti graphics-processing unit (GPU) and boosted by exclusive GPU Tweak technology.
The GeForce GTX 780 Ti GPU is powered by 25% more CUDA (Compute Unified Device Architecture) cores and benefits from a boosted clock speed of 928MHz - both significant increases on its predecessor that enable ASUS GTX 780 Ti to deliver superb gaming performance.
GTX 780 Ti includes the GPU Tweak utility that's exclusive to ASUS graphics cards. This easy-to-use tool hands users a variety of unique controls that enable them to squeeze the very best performance from GTX 780 Ti. These include the ability to control finely GPU and video-memory clock speeds and voltages, cooling-fan speeds and power-consumption thresholds in real time - so overclocking is both easy and can be carried out with high confidence.
As well, the GPU Tweak Streaming tool lets users share on-screen action over the internet in real time - so others can watch live as games are played. It's even possible to add a title to the streaming window along with scrolling text, pictures and webcam images.
ASUS GTX 780 Ti includes the latest innovations to deliver faster, smoother and sharper graphics for the best gaming experience.
NVIDIA® GPU Boost 2.0 cranks up the GTX 780 Ti's clock speed while allowing full control over the power and temperature - delivering faster visuals for a better gaming experience.
GTX 780 Ti also benefits from NVIDIA PhysX® and for more accurate simulation of real-world physical interactions and NVIDIA TXAA™ temporal anti-aliasing technology, a Hollywood-style special effect that results in smoother and sharper graphics. The new card also comes with GeForce ShadowPlay, a recording utility that lets users capture their proudest gaming achievements - all the way up to Ultra High Definition (UHD/4K) resolutions.
ASUS GTX 780 Ti is loaded with 3GB of ultra-fast GDDR5 memory allows gamers to maximize their enjoyment, while support for the latest DirectX 11.2 standard enables on-GPU tessellation allowing more and incredibly detailed geometry to be packed into game scenes - characters come to life with detail levels that rival blockbuster movies.
With NVIDIA 3D Vision Surround technology built in, ASUS GTX 780 Ti supports multiple displays, so gamers can generate a breathtaking view of the game world across three screens - all while using a fourth display for other tasks, such as chat or web browsing.
Specification:-
- GeForce GTX 780Ti
- GPU: GeForce GTX 780Ti (GK110)
- Core Base Clock: 876MHz
- Core Boost Clock: 928MHz
- Memory Clock: 7000MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Was [£599.99] Inc. VAT
Only £539.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 780 Phantom 3072MB GDDR5 PCI-Express Graphics Card @ £379.99 inc VAT
The new GeForce GTX 780 is all about hyper-realistic gaming and next generation technology. The GeForce GTX 780 features the same record-breaking GK110 GPU used in GeForce GTX TITAN. The massively powerful NVIDIA Kepler ™ based GPU contains 50% more cores than its GTX 680 predecessor AND comes with 3GB of high-speed GDDR5 and NVIDIA GPU Boost 2.0 technology. GeForce GTX 780's 384-bit memory interface provides up to 288.4GB/sec of peak memory bandwidth to the GPU. All this combines to give you over a 40% gaming performance upgrade.
Features:-
- Gigantic 3GB GDDR5 memory for the best gaming experience & the best resolution
- NVIDIA GPU Boost 2.0 Technology for intelligent monitoring of clock speed, ensuring that the GPU runs at its peak and the game is at its highest frame rate possible. It offers new levels of customization, including GPU temperature target, overclocking, and unlocked voltage
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- Bring games to life with NVIDIA® Surround™ multi-monitor gaming on a single card
- PCI Express 3.0 Delivers double bandwidth per lane of PCIe Gen 2 for faster GPU - CPU communication
Specification:-
- Core Base Clock: 902 MHz
- Core Boost Clock: 954 MHz
- Memory Clock: 6008 MHz
- CUDA Cores: 2304
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
Was [£395.99] Inc. VAT
Only £379.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 780 WindForce 3x OC Rev2.0 3072MB GDDR5 PCI-Express Graphics Card (GV-N780OC-3GD) @ £379.99 inc VAT
Brand-new instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up MONITORING, GPU CLOCK, MEMORY CLOCK, FAN, GPU VOLTAGE, Memory VOLTAGE, OSD, ONLINE SUPPORT and update driver, BIOS directly.
Keeping the same 450W Cooling capacity using only 2 slots, the New WINDFORCE 3X 450W cooling system is equipped with two 8mm and four 6mm cooper heat-pipes , inclined fans, and GIGABYTE “Triangle Cool” technology. This not only provides an effective heat dissipation capacity but GPU Boost 2.0 technology also enables higher performance due to a lower temperature.
In the Kepler architecture, support up to four displays on a single card. Satisfy your mulit-screen steup, high definition and extreme gaming experience.
Features:-
Specification:-
- Rev2.00
- WINDFORCE 3X 450W Cooling system
- Black PCB
- Core Base Clock: 954 MHz
- Core Boost Clock: 1006 MHz
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power Connectors: 2x8-Pin
- Warranty: 3yr
Was [£399.95] Inc. VAT
ORDER NOW
Gigabyte GeForce GTX 780 WindForce 3x "GHz Edition" 3072MB GDDR5 PCI-Express Graphics Card **OcUK Exclusive** @ £409.99 inc VAT
Features:-
- OcUK has secured an exclusive, only OcUK will receive stock in November!!
- GHz GTX 780 GPU - Best for Overclocking!
- Boost clock OC to 1071MHz
- Enhanced back-plate for asthetics
- 8-Phase Power Design
- WindForce 3X 450W Cooling System (2-Slot Design)
- Black PCB
Specification:-
- GPU: GeForce GTX 780 GHz
- Core Base Clock: 1019 MHz
- Core Boost Clock: 1071 MHz
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Was [£449.99] Inc. VAT
Only £409.99 inc VAT.
ORDER NOW
MSI Geforce GTX 780 Gaming Edition OC 3072MB GDDR5 PCI-Express Graphics Card @ £379.99 inc VAT
Features:-
Specification:-
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Only £379.99 inc VAT - THIS IS THE OC VERSION!!
ORDER NOW
MSI GeForce GTX 780 Lightning LE 3072MB GDDR5 PCI-Express Graphics Card @ £399.95 inc VAT
MSI, world renowned graphics card and motherboard manufacturer, has officially announced the release of the GeForce GTX 780 LIGHTNING. This product uses the new exclusive Triple Force Architecture and is equipped with a Triple Level signals LED. The card, from the inside out, represents the next revolution thermal design. The combined power of the Twin BIOS and the card's Enhanced Power Design equip gamers and extreme overclockers with the best graphics card. This superior performance is accompanied by a 20-phase power design that can unlock the limitless potential of the graphics card. Also featuredis the patented GPU Reactor powered back plate design which filters power supply noise and improves overclocking stability. The MSI GeForce GTX 780 LIGHTNING is built using Military Class 4 components that have passed rigorous certification testing in laboratories. With such powerful components, this graphics card is guaranteed to have an impressive service life and excellent overclocking stability. Additionally, the popular 3x3 OC Kits allow for gamers to effectively monitor the status of the graphics card. MSI products are renowned for leading the industry due to the company's innovative R&D, excellent performance, streamlined thermal design, and quality components and software. The MSI GeForce GTX 780 LIGHTNING is once again the most powerful graphics card.
The latest generation of MSI's GeForce GTX 780 LIGHTNING uses Triple Force Architecture. Equipped with a Triple Level Signals LED function, TriFrozr Thermal Design with independent fan control system, and PureDigital PWM control. The Triple Level Signals LED features green, blue, and red lights that represent light, medium and heavy power loads on the device. This ensures that players have complete control over their games or the overclocking process. The innovative TriFrozr Thermal Design with independent fan control far exceeds any traditional or custom cooler's thermal performance and ensures better cooling of the GPU, memory and PWM modules. This iteration of MSI's exclusive design builds upon the PropellerBlade and the Dust Removal Technology of the previous model, alongside seven 8 mm SuperPipes for unrivaled thermal performance. In addition, the PureDigital PWM control technology provides a more stable and accurate voltage signal than traditional designs. The PWM's reaction time is shorter and helps enthusiasts more achieve a higher stability in the most stressful of environments.
Twin BIOS is composed of an original BIOS and overclocking BIOS. The original BIOS allows users to obtain better performancethrough out of the box overclocking, while the overclocking BIOS is specifically designed for extreme LN2 overclocking. By removing restrictions, the capabilities of the graphics card are dramatically increased, which allows users to unlock the card's full potential. The enhanced power supply provides more phases of power than standard models. The GPU has 16 phases, which more than doubles the capabilities of standard designs. The memory of the power supply even has a independent power source, which further supports a foundation for extreme overclocking. Not to mention that MSI's exclusive, patented GPU Reactor filters out extra noise for a stable overclocking experience.
MSI always emphasizes top quality and stability when pursuing the highest in product performance. When developing products, MSI makes satisfying market demands and expectations its primary purpose. The MSI GeForce GTX 780 LIGHTNING introduces the latest Military Class 4 components to the series. The components have gone through rigorous testing in a laboratory to satisfy the Military Standard 810G. Regardless if it is the advantages of the low-temperature, high performance DrMOS 4, the double-sided CopperMOS thermal design, the highly durable and stable tantalum Hi-C Cap cores, the polished surface of the New SFC for added cooling, or the corrosion proof Dark Solid CAP, each aspect of the LIGHTNING ensures the best possible stability.
Designed specifically for overclocking, the 3x3 OC Kits are a must-have for all enthusiasts. The kit allows users to adjust the voltage levels GPU, memory, and PLL through MSI's exclusive Afterburner utility while monitoring GPU, memory, and MOFSET temperatures. V-Check Points also capitalize upon the multi meter measuring of GPU, memory, and PLL voltage levels to give users direct calibration data-a function that guarantees success in the world of extreme overclocking.
Features:
- 16+3+1 (20) Phase Power
- Propeller Blade Technology
- 8 SuperPipes and dense aluminium fins to maximize thermal dissipation
- LN2 Mode
- Triple level signals show the real-time load with different colours
- TriFrozr Thermal Design - Three PWM fans with independent control on the most advanced thermal design.
- Pure digital PWM Control - Digital GPU / Memory / AUX voltages
- Twin BIOS
- Enhanced Power - 16 GPU phases and 3 memory Phases on a custom designed 10 layers PCB for amazing overclocking potential.
- GPU Reactor for improved OC ability providing 300% higher power capacity and reduces power noise (ripple)
- MIL-STD-810G standard certified to ensure the best stability and quality.
- Uses DrMOS 4, CopperMOS, Hi-c CAP, new SFC and Dark Solid CAP.
Specification:-
- Core Base Clock: 889 MHz
- Core Boost Clock: 941 MHz
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- Warranty: 3yr
Was [£439.99] Inc. VAT
Only £399.95 inc VAT.
ORDER NOW
EVGA GeForce GTX 770 SC ACX Dual Bios 2048MB GDDR5 PCI-Express Graphics Card with FREE EVGA Backplate (02G-P4-2776-KR) @ £269.99 inc VAT
Fast just got faster with the next-generation EVGA GeForce GTX 770, a high-performance graphics card designed from the ground up to deliver high-speed, super-smooth gaming.
EVGA is also introducing a brand new cooling design; the EVGA ACX cooler. This revolutionary double ball bearing fans with an average lifespan of 12 years. This is 4x longer lifespan vs competitors sleeve bearing fans! Not to mention this fan is silent, in factr it is 15% quieter on average!
The EVGA GeForce GTX 770 is stacked with unique gaming technologies like NVIDIA GPU Boost 2.0 that make it fast. Really fast. So nothing will hold you back from taking on - and dominating - your most challenging games.
Specification:-
- Dual BIOS Version
- Core Clock: 1111MHz (GK104)
- Core Boost Clock: 1163MHz
- Memory: 2048MB GDDR5
- Memory Clock: 7010MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2222MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 230 watts at stock speed)
- 1x 8-Pin & 1x 6-Pin PCI-E Connectors required
- Warranty: 3 Years
Was [£275.99] Inc. VAT
Only £269.99 inc VAT - WITH FREE EVGA BACKPLATE
ORDER NOW
Gainward GeForce GTX 770 Phantom 4096MB GDDR5 PCI-Express Graphics Card @ £279.95 inc VAT
Gainward GTX 680 Phantom, continue the elegant design of the first generation. The new Phantom III comes with brand new fins design (patent pending) that introduces 1) better thermal performance 2) lower acoustic level 3) more solid structure than previous generation. With this new outstanding innovated thermal design and optimized product design Gainward GTX 770 Phantom delivers an extreme gaming performance for enthusiast gamers.
Gainward Grand-Prix Heat-Pipes Hybrid Cooler, was designed in 8mm copper-water heat-pipes on a copper base conducting heats away from GPU at highest efficiency, then dissipating onto aluminum heatsinks, which are forced ventilated with Great 8 cm silent PWM fans (GR8) which are also removable.
Great 8 cm silent PWM Fan (GR8) achieves highest cooling performance at much lower temperatures under power saving mode.
Specification:-
- Core Clock: 1046MHz (GK104)
- Core Boost Clock: 1085MHz
- Memory: 4096MB GDDR5
- Shader Clock: 2300MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
Was [£319.99] Inc. VAT
Only £279.95 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 770 WindForce 3x OC 2048MB GDDR5 PCI-Express Graphics Card (GV-N770OC-2GD) @ £249.95 inc VAT
The next generation GeForce GTX 770 is a high-performance graphics card designed from the ground up to deliver super-fast, smooth and quiet gaming. It features the most advanced technology innovations, engineering and features to deliver spectacular performance in today's most demanding games.
Features:-
- NEW WINDFORCE 3X 2 Slot 450W fan sink with "Triangle Cool"
- Core/Mem clock: 1137 MHz (std 1046MHz)
- Boost Clock: 1189 MHz (std 1085MHz)
- 8-Phase power benefits with GPU Boost 2.0
- OC GURU II with GPU Boost 2.0 Technology
Specification:-
- Core Clock: 1137MHz (GK104)
- Core Boost Clock: 1189MHz
- Shader Clock: 2220MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
- Product Review: http://www.eteknix.com/gigabyte-geforce-gtx-770-oc-windforce-2gb-graphics-card-review/17/
Was [£269.99] Inc. VAT
Only £249.95 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 770 WindForce 3x OC 4096MB GDDR5 PCI-Express Graphics Card GV-N770OC-4GD) @ £299.99 inc VAT
On board 4GB of GDDR5 memory, satisfying your multi-screen setup, high definition and extreme gaming experience.
Features:-
Specification:-
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
Only £299.99 inc VAT.
ORDER NOW
MSI Geforce GTX 770 Gaming Edition 2048MB GDDR5 PCI-Express Graphics Card @ £239.99 inc VAT
The GeForce® GTX 770 delivers more than just state-of-the-art features and technology. It gives you truly game-changing performance that taps into the powerful next-generation GeForce architecture to redefine smooth, seamless, lifelike gaming.
Immerse yourself in an ultra-smooth gaming experience with exciting new NVIDIA technology advancements like NVIDIA Adaptive Vertical Sync. It’s a fast, seamless way to adjust VSync to your current frame rates for maximum playability.
Features:-
- Innovative new GeForce architecture, designed to deliver faster, more power-efficient performance
- NVIDIA GPU Boost technology that dynamically maximizes clock speeds to push performance to new levels and bring out the best in every game
- The power to turn on lightning-fast anti-aliasing in a huge variety of games, automatically, with NVIDIA FXAA
- The power of 3-way NVIDIA SLI® technology
- Ultra-smooth gaming experience with exciting new NVIDIA technology advancements
- NVIDIA 3D Vision® Surround multi-monitor gaming on a single GPU (three gaming monitors plus one accessory display) - for the first time ever
- Supercharged NVIDIA PhysX® and NVIDIA 3D Vision® performance
- New 28nm process means cooler, quieter and far superior overclocking potential than previous generation graphics cards
Specification:-
- Core Clock: 1059MHz (GK104)
- Core Boost Clock: 1111MHz
- Shader Clock: 2118MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
Was [£259.99] Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
KFA2 GeForce GTX 780 HOF 3072MB GDDR5 PCI-Express Graphics Card **ALL WHITE** @ £419.99 inc VAT
Exclusive to Overclockers UK we have the worlds fastest air-cooled GTX 780 - the KFA2 GTX 780 LTD OC or better known to some as the Galaxy Hall of Fame. With many premium and unique features such as Hyper Boost Hardware for maximum clock speeds and cooling. The first GTX 780 to use hybrid heat pipe plus vapor chamber cooling for near silent operation yet very low temperatures. Built and designed using 8+2 phase digital power, premium POSCAP and MLCC capacitors all based on a stunning white looking PCB. If you want the fastest GTX 780 on the market and one which looks different to any other, then look no further!
Features:-
- Hyper Boost hardware overdrive switch supercharges your core clocks
- World’s fastest air-cooled GTX 780 with 1058Mhz boost clock
- 1st GTX 780 with hybrid heat pipe + vapor chamber cooling
- Premium POSCAP and MLCC capacitors
- Winner of multiple overclock world records
- 8+2 phase digital power
- Voltage read points
- Custom white PCB
Specification:-
- Core Base Clock: 1006 MHz
- Core Boost Clock: 1058 MHz
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
http://hexus.net/tech/reviews/graphics/60001-kfa2-geforce-gtx-780-hall-of-fame/?page=12
Was [£469.99] Inc. VAT
Only £419.99 inc VAT.
ORDER NOW
Some incredible deals here guys, these prices end Midday-Monday or when the product sells out, whichever comes first!!
I sold my 770 Lightnings and bought the Inno3D GeForce GTX 780 iChill HerculeZ X3 Ultra DHS Edition. I hear the DHS Edition is great for OC'ing.
Can't wait to play with it:)
Features:-
- Black PCB
Specification:-
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
ORDER NOW
If the missus asks, its because you didn't have the one I wanted
Hey Gibbo one of the competitors which sounds like abs has the GTX 780 Gigabyte WF available for £376 Delivered with a winter sale code. Anything you can do? :D
