So I'm trying to film my racquetball games. 60 FPS is soooo much better, but the file size limit is 4GB, and there is no 720P 60FPS camcorder option. Is there another app someone can recommend that will allow me to record in 720P 60FPS?
LTE is only shown if you have a 4G SIM which three doesn't have yet.
Is there any easy way of changing the onscreen menu button for the task switcher button that is on all the nexus devices? Or do you need a ROM?
as I am testing the dynamic mode as of today..we'll compare later on
bought it from http://www.ebay.com/itm/For-LG-G2-SAFFIANO-Silm-Soft-Jelly-Case-Tpu-Silicone-Rubber-Cover-/251361797770?ssPageName=ADME:X:RTQ:US:1123
perfectly fitted my D802 no problemo
So i finally took the plunge and bought one last night. Black 32GB from ebay.
My plan of action when it arrives:
1) Flash a stock RUU. I've never owned an LG so i want to check how to revert to stock in case all goes **** up
2) Root
3) Install TWRP
4) Flash Stockmod ROM
5) Install Xposed framework + modules
6) Possibly have a look at Xdabbeb's camera mod
Got a black one of these today. Really like it.
Much better grip than the hard shell case I was using.
Bottom sags a bit on mine I think this is because I still have the plastic on the sides of the phone.
But main thing is the screen saver stays on
Well recommended!
Glad you liked it mate..as I have Nekeda, Diztronic.and Nillkin case, I always returned to this Nekeda case. It is the best so far..I have removed my ultimateshield as it was ruined by Dizteonic case..there goes £7.99..
I feel your pain mate.
You have no screenie on then ?
If the phone is unlocked and the D802 version it'll work on all uk carriers. Do you want 32gb or 16? 32 is only available to O2 customers in the UK, so if you want that you'll have to buy an import from Europe or Hong Kong (they will work fine here if its D802). If you're happy with 16gb then you should be looking to pay less than that (my 32gb was £390), I can't help with where from though.
Grrrrrrrrrrrrrrrrrrrrrrrrr thank you I find phones a bloody nightmare
Is there a way you can send me a private link to any trusted sites to buy from?
great plan
ive done the exact same apart from Xposed framework
dont forget StockMod Kernel: http://forum.xda-developers.com/showthread.php?t=2525446
