Greetings... again.
REVIVAL OF THE DEAD THREAD! DOM DOM DOMMMM!!!!!
Seriously though... this mic issue is a problem for years now. The AMOUNT of forum posts scattered over the internet, I'd wager are in the thousands. Not only this but it's irrelevant of sound card, or mic.
I've tried:
Changing settings.
Trying 3 different mics in 3 different mic ports. Oh yes. Many combos! These have all been properly selected as defaults and max volumes picked.
I've tried enabling / disabling exclusivity to VOIP applications.
I've turned off sound levelling, or quietening the volume when a call comes in.
I've tried different drivers on Windows 7.
I've tried different drivers on Windows 8.
I've tried different drivers on Windows 8.1
I've tried Windows 8 64 bit drivers on Windows 8.1
I've updated bios.
My PSU died so I got a SuperFlower Golden Green HX 650w.
There is no problem with the grounding on my circuitry.
No it is not any of the hardware itself.
I've tried default windows drivers and no ASUS software at all!
I've even tried a well known, well liked desktop microphone which is known to be excellent: one of the Blue Snowball mics. That is powdered USB and it STILL had ridiculously quiet recording volumes.
Is it the recording volume itself? Nope.
How do you know this for certain? Well, game volume is as loud as it should be, so why on earth would the recording (on max) be mixed in too low? Shouldn't happen. + testing on sound recorder gives the same problems.
Apart from the nooblars who set the wrong settings, or don't sort out the majorly obvious, go take a trip to google and see just how WIDESPREAD this damn issue is.
I have tweeted numerous times over the months (for ages now), @Microsoft and @Windows and @Windows_Support but to no avail.
Longstanding issue in Windows 7 and 8. Doesn't exist on XP. Suspicious, no?
Unbelievable!
I
****ing HATE Windows, but because of the monopoly man and Microsoft getting together and riding DirectX, I am stuck with a multitude of games that are simply not compatible with Linux.
Oh which reminds me... mic works fine on Linux, with generic drivers. LOL @ Windows.
The driver database and list of supported devices on Windows has grown so large that Micro
**** will persistently ignore OS issues unless 10,000+ people complain about it simultaneously using social media. Otherwise, unless it's a security threat, it will be ignored.
Tired of that, "oh, turn boost on"
********. As if we all haven't tried that crap already!
Note: transmit audio from my mic over applications such as Skype is fine. It's the recording volume. However this is irrelevant to the program recording the sound. If I test in Windows, the audio from my mic only ever lights up the green bar if I eat the microphone. Sound recorder does the same. Fraps does the same. Bandicam does the same. Etc.
Extra note:
Tried 2 analogue mics. 1 USB.
Tried both Analogue mics on on board back, onboard front and the installed Xonar DG as well. Applying all the correct settings and setting appropriate defaults. Bare in mind that I have done this combination over 2 different OSes with a multitude of drivers (or with generic Windows ones), fiddled with all the appropriate boost setting, program settings, exclusivity, blah blah blah blah.... same goes with USB, only via a USB port obviously. So many combos, if this was a bank pin, you could dish it out and serve the population, chip n' pin.
Madness!
Even though I've updated various things. This includes USB chipsets. Various other chipsets. Bios, etc. Nothing still works.
Perhaps the GA-Z77-D3H rev 1.0 is the problem? It's not broken, but maybe it's just awfully
**** at handling EVERYTHING... even though it shouldn't because, well... Xonar DG isn't on board.
