Nicotine isn't a carcinogen either you tool, it's the tar, carbon monoxide and 400 plus other chemicals in fags that give you cancer, the nicotine is merely the addictive agent.
But I see you avoided my question so I'll ask again. Why, if nicotine is as toxic and cancer-inducing as you claimed, is it licensed and prescribed by nearly every major Western healthcare system on Earth?
Now, to rebut your 'facts' one by one.
"Nicotine is at least 1000-2000x more toxic than caffine"
Wrong, the median lethal dosage of caffeine for a human is around 4-5 grammes, the lethal does of nicotine is around 40-60 milligrams. So taking both in their purest form (which no one would do) the difference is 100 at most, a whole order of magnitude lower than you stated.
Furthermore when you look at how both are used in reality the difference becomes even lower. A smoker absorbs around 1.2mg of nicotine in each cigarette, someone drinking a 100 ml cup of coffee will consume 40mg of caffeine. So whilst it would take around 42 cigarettes smoked in one go to create the possibility of death, it would 'only' take someone downing 125 cups of coffee in the same time frame to be at the same risk of mortality.
So in real terms, and putting in the context of how each is used, at best caffeine is only 3 times less toxic than nicotine. I haven't even mentioned e-cigs yet which aren't as efficient as cigarettes at delivering nicotine.
"is far less addictive (although shows limited addictive side effects)"
If we define an addiction as something you do several times every day and feel negative side-affects with withdrawal then 80% of the Western world are addicted to caffeine (most of home will never realise they are until they try and go 'cold turkey' and start getting headaches and nausea.)
So whilst pound for pound nicotine is more addictive, caffeine is far more addicted to and , like above, more addictive as a consumable unit in the context of how it is taken.
"and is not carcinogenic"
Like nicotine then. Whilst you can cite 'studies that link it to cancer' there is no known or accepted scientific notion that nicotine causes cancer and imply it is (as you have) is a downright lie. In terms of finding studies that link anything with cancer, this is pretty easy and you only have to read the Daily Mail headlines to see how many things get 'linked' with it.
Until you can prove and convince the rest of the medical and scientific world that nicotine is a carcinogen, I'd suggest you are making yourself look foolish at worst, and dishonest at best by keep posting that it is one.
For the most part, utter garbage. Even taking your hand picked numbers it is still patently obvious how much more toxic nicotine is than caffeine, even under everyday use age. It is is physically impossible to drink 125 cups of coffee, you would die from the water alone long before you got to that stage.
You can ignore all the science you want on the carcinogenic properties of nicotine but the facts are there for others to read. Giving nicotine to lab animals has been shown to directly cause cancer, that is a plain fact. That evidence is sufficient to ban many chemicals for being carcinogenic.
As for addiction, yes of course caffeine is addictive, no one has said otherwise. The point is if someone is addicted to caffeine then it is far simpler to quit with more mild withdrawal symptoms than nicotine. People can break a caffeine addiction with minor detrimental effects at a high success rate. Nicotine addiction is very similar to cocaine or heroine and often requires medical intervention and at best is a difficult process with a much lower success rate.
Those who live in glass houses etc..
