I have the evo blue 750w. Solid unit.![]()
Good to know I got decent PSU, after working everything out got about £20 to spare, so is there anything need tweeking better Ram or cooler may be
Let us know thanks
If I go for the 8320 will it work straight out of box with either of the 2 motherboards you suggested above (no bois update needed)
Ok my last 3 questions then I will leave you alone and start spending (can't wait)
1. Will I see big difference if I get fx8320 instead of fx6300
2. I the GPU listed above the best R9 270X
3. Will a bios update be needed to get fx8320 to work with Asus M5A97 EVO R2.0 or Gigabyte 970A-UD3P as it is not possible for me to perform
Ok I was thinking going with the fx6300 and use extra dosh to spend on slightly better board so in the future I will have better overclocking ability, the choice to upgrade cpu and may be crossfire the gpu, what do you think
Any tips on better board, I was thinking Asus M5A99X PRO R2.0 AMD 990X or Gigabyte 990FXA-UD3 AMD 990FX what do you think
not sure how vram works but I get you on the rest, can't stand the colours in that board (990XA-UD3) Sounds silly but really like the black and grey scheme, would the Gigabyte 990FXA-UD3 AMD 990FX be a good board with 6300/R9 270x, then in future just upgrade cpu and gpu
