You need a proxy for the PC, I used Softether. Free and works a charm
Will connecting via Hola via Chrome be enough or will I need to manually amend the proxy settings on the PC?
So once it's downloaded do I need to do anything special to play or just run in Origin? Or VPN still?
If you want to play it before it's release you need to load Origin through a VPN, then disconnect once you start playing TF.
It fairly sad that there are already generation 2 pilots about.
Thanks mate... Strange, I've connected to a Korean VPN and I've logged in to Origin but still can't play.
Whenever I try to play I get an unreleased title error.
According to the reddit, all the bugs are still there from 'beta' and all the other classic EA stuff.
Probably be a day one patch when it actually launches.
