Just wanted to say a massive thank you to everyone that helped me making my choices..I ended up with the Intel I5,the Msi 2gb card and 8gb of ram..just a quick question concerning my Ram..it is the TeamGroup Vulcan ORANGE 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit ,do i set it up at the full 2400MHZ in my Bios? ( i have it at 1800 at the moment) also my I5 is 3.4GHZ turbo to 3.8GHZ,can i set it up to 4GHZ without having to much to worry about? I use a corsair H50 cooler..Thanks Guys
ps in Bios my Mem is indeed on 11,13,13,35 Thanks Walder...PS scratch that Walder..i opened up prime 95 and core speed is 3999.07, and spd slot 2 and 4 (my mem is on those slots) last column shows XMP-2400 and under that Freq at 1200 MHZ,i hope thats right Cheers mateCheers WalderX i think ive done it ok in Bios ..CPUZ is showing (RAM) type=Dual,NB FREQ=799.8 MHZ,Dram Freq=1199.8 MHZ,....(PROCESSOR) Core speed 799.81 MHZ, Multiplier x8,Bus speed 99.98 MHZ..I havent a clue what all this means thoughps in Bios my Mem is indeed on 11,13,13,35 Thanks Walder...PS scratch that Walder..i opened up prime 95 and core speed is 3999.07, and spd slot 2 and 4 (my mem is on those slots) last column shows XMP-2400 and under that Freq at 1200 MHZ,i hope thats right Cheers mate
Yeah it is right. It will show as half because it is Double Data, so 1200 x 2 = 2400MHz. My 1600MHz Ram shows as 800 in CPUZ.
...cheers guys
forgot to mention the cpuz thing, as correctly asvised by lee it shows the base clock rate of the ram rather than the ddr rate. To be honest they should probably update it to show the full ddr speed these days!
