No Z87 notherboards with PCI?
8X/8X so as good as a normal full size board that does 8X/8X, also you use the two green slots furthest apart to give a little extra room between cards. But that does mean the case will need an additional expansion slot beneath the board if using a dual slot thick GFX card.
Someone reviewed it to say the sound was better than the D1 anyway. Nice.
Got this in my basket.
Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - Retail
£169.99
(£141.66)
£169.99
(£141.66)
Gigabyte G1.Sniper M5 Intel Z87 (Socket 1150) DDR3 Micro ATX Motherboard
£143.99
(£119.99)
£143.99
(£119.99)
Parvum Systems S2.0 MicroATX Case - Black with Green
£139.99
(£116.66)
£139.99
(£116.66)
What cooler would you recommend, stay with stock until I get water or?
If you use tall RAM then water cooling is best as you are guaranteed to clear the tall heatspreaders.
Yeah.
But remember what I said about your SATAII SSD and these chipsets, I think you will find it doesnt work.
Another question for you lovely gentlemen. Placing a order with mdpc do i need any tools or crimpers? is it just heatshrink and braid?
