Hi All,
Hoping some of your experts will be able to provide some assistance.
We have just moved into a new place and we have a Low pressure mavity system
http://www.mirashowers.co.uk/common/images/systemDiagram-lowPressureGravity-print.gif
When we look at the water pressure of the shower, it is pretty appalling. The water pressure in the bath and sink is fine, just the shower.
We have a bar mixer tap, not sure what make it is as it does not seem to have any name or markings on it. Similar to the one below.
[IMG]http://www.wet-water.co.uk/components/com_virtuemart/show_image_in_imgtag.php?filename=MIX5900__Thermos_4f55dd067b427.jpg&newxsize=500&newysize=500&fileout=
We removed the bar mixer to have a look at the filters to see if they were dirty or anything, which they were not. We also checked the water pressure coming out of the pipes without the bar mixer installed and it looks pretty good, so this is leading me to believe that the mixer tap is the bottleneck.
So, my question is: What other type of mixer can I replace this with that will allow a greater flow rate and hopefully improve the pressure coming out the shower?
Looking to spend about £100 to £120
Thanks for the help
[B][COLOR="Cyan"]DO not hotlink images.[/COLOR][/B]
Thanks for the help
