Asus Geforce GTX 760 Striker 4gb
Highly unlikely. Use Andand Tech to view the benchmark, but your not doubling your capacity, simply speeding the rendering up by adding a new card,but it won't out perform a 780Ti, not by a long shot.
What do you have currently and what's your budget?
Do two of these beat a 780ti?
I'm thinking about buying two from overclockers, or i might wait til the dual version comes out
http://www.overclockers.co.uk/showproduct.php?prodid=GX-342-AS&groupid=701&catid=1914&subcat=1830
Here is a good comparison between 1 x 760 and 1 x 780 Ti -
http://www.anandtech.com/bench/product/1038?vs=1072
And remember it is not 100% scaling so don't just times the results by 2, Times it by 2 and then take a bit off.
Personally I would just get a 780 Ti :p
I bought 2 of these and it's just around a 780Ti. These gpu's are lookers, but they aren't cheap. I bought mine more for my theme and also I don't game all the time and when I do it's in less demanding games. When the real 800 series 18 or 20mn release I hope to give my Asus Strikers to my son:)
I'm only upgrading once the cards are 20nm.
I have a gtx 770 currently. Budget is about 600 quid. I was thinking about getting two gtx 760 strikers, or another 770 to match my msi oc gtx 770. Or a 780ti.
I seriously think people should stop giving fresh money for the GK104 old milk...
Even for people that would buy Nvidia only, the GTX780 would be a far better choice than that glorified GTX760. At £240 it is pointless and not worth noting nor praising...if it was at £150-£160, then it might be different...
Even at that price I would consider a 2nd hand 280x!
http://www.overclockers.co.uk/showproduct.php?prodid=GX-014-IN&groupid=701&catid=1914&subcat=1341
389, cheapest 780 atm here,, The price difference for a lot of users is too much to afford so they buy a lower card ,, Thats why both venders have cards of different tiers and prices. Doesnt mean there silly just they have a budget to stick with.
While I do agree with you on Gk104 milking. It's still a good gpu. I bought one only for the theme of my new rig. I'm waiting for 20nm. So these will hold me until then. I'll give to my son. Also these gpu look awesome and that what I was looking for. Don't care what others think tbh
If people were to drop £240 on a GTX760, they'd be much better off trying to gather a couple more tenners for a 2nd hand GTX780.
The GTX760 at £240 is a joke, considering the GTX670 4GB were £199.99 when EOL and was a better GPU. Also GTX770 2GB can be had at this price point as well. So it's effectively a cripple GTX670 with 4GB vram vs a pimped up GTX680 with 2GB vram at the same price...
