The 290 Vapor X is voltage locked. You can give it up to +200 offset but it will force the voltage to stay just under 1.3v. Other 290s can go higher like the Lightning and the reference cards I believe though.
Also keep in mind if I were to go with AMD again, it would be the 290x Vapor X this time. Not the 290p
My Vapor-x (non x) that I bought recently goes past 1.3v when I put +200 offset.
Just did a run of Firestrike extreme clocked at 1225/1600 and the voltage was 1.352. It has been as high as 1.38.
I never ran that bench, but in Valley and Heaven it will go up to 1.35. Though vdroop will force it down to 1.29 most of the time.
I say it is locked because even putting +300mV offset on it yields the exact same amount of voltage as +200.
I think the Tri-x is not locked but if you have had various Amd cards going faulty you would be better going Nvidia. I have had no problems with my Msi 290 or Vapor-x or 4850 or 5850 before that. I find it strange certain people have such trouble with Amd cards.
Really? You must have an immense card then because I'm 2000 points off the Heaven score I got with my classy, unless you mean at stock.
290X Vapor-X
My 780 Classy was equal to, or slightly slower than my 290P PCS+
Because yours was ****. If you'd have flashed the bios and allowed it some extra voltage you'd probably got a lot more out of it.
????? I did do that, I had it at 1.3v
Err!
It was just a ***** one then. What clocks did you get out of it?
290X Vapor-X
