Gpu 2 drops to 500mhz on the core in some games (payday2 for example) and I get horrendous texture flickering. At default 1150/1600 they seem okay. How do I stop the 2nd gpu from dropping its clocks? I have the clocks set to stock in MSI AB already.
turn up the power limit to +20
Try this for a fix for the clock dropping. No need to use unofficial overclocking method either so clocks will drop to 2d levels as normal.
1. Download RadeoPro - http://www.radeonpro.info/2013/11/new-build-with-support-for-amd-radeon-r-series/
2. Create a profile using the game exe.
3. Click the profile tab, then the overdrive tab. Click the padlock to unlock overdrive, click enable graphics overdrive, the click 'always use highest performance clocks while gaming'. Don't forget to set +50% power tune in RP. Apply clocks and voltage settings through afterburner first. Now right click the game profile shortcut on the left and select apply then launch the game.
Have done that, but gpu1 now sticks at 1150. Worked a treat for gpu2 but I'm still getting horrible artifacts.
Copy my settings. This will sniff out a faulty or unstable gpu. If you get any errors at stock clock/voltage settings, then you know its faulty.
Artifacts usually indicate an unstable core. The gpu doctor recommends 15-30 minutes of OCCT at these settings to sniff out an unstable core.
It seems like it's stuck at 1.188V (default boost is 1.256V so this might be a tad low). AB doesn't seem to want to change it.
Any idea how to fix powerplay on GPU1 after using the radeonpro fix you mentioned?
(E: figured it out)
Oh I just mean the power play thing. Just reset overdrive in CCC. A bit of research shows that 1.188V is the stock volts for 1100/1600, and 1.256v is for the 1150 boost. It isn't going to 1.256v in game, so maybe 1150 is unstable at 1.188v. I'm gonna drop to 1100/1600 which should then put me at stock volts and clocks to see if that fixes it.
Texture flickering only occurs after maybe 30 mins of gameplay so I'm wondering if it could be a heat issue. Supposedly toxics can have issues with VRAM temps.
