Corsair Dominator Platinum DDR3 2400MHz CAS9 Review.
Caporegime
17 Jan 2010
weston-super-mare
STU_REV_CORSDOM1_zpscdde5895.png~original
Corsair Product SKU - CMD16GX3M4A2400C9
Today I will look at the Corsair Dominator Platinum 2400MHz 16GB (4x4GB) dual/quad channel RAM kit with impressive timings of 9-11-11-31 when XMP is set.
Packaging.
IMG_5561_zps1764c9dd.jpg~original
IMG_5560_zps51bc9a30.jpg~original
IMG_5558_zps337f0091.jpg~original
The sticks come in a cardboard box, each stick is secured within its own plastic clam-shell held inside the box by soft foam.
The RAM modules.
IMG_5541_zpscc9bdc71.jpg~original
IMG_5550_zps7ba77ba6.jpg~original
The RAM timings are very tight indeed and I believe some of the best to be found in the 2400MHz range.
Being Ver 4.13 they are made using Samsung IC's - http://forum.corsair.com/forums/showpost.php?p=343672&postcount=1
IMG_5551_zps1ac4f673.jpg~original
The heatspreader is made from aluminium and the light bar is also easily changeable to other kits available from Corsair Light Bar upgrade kit.
You can also see the Corsair Link connector which can be used to monitor activity and temperature.
IMG_5566_zpsa7393d88.jpg~original
The light bars also illuminate which gives a nice soft glow.
Test setup.
i7 [email protected] (Speedstep/turboboost disable so always 4.4GHz)
Z97 SOC Force
Corsair Neutron GTX SSD
Sapphire R9 290 vapor-X
Kingston hyperX 2400MHZ CAS11
Corsair Dominator Platinum 2400 CAS9
Overclocking.
These have to be some of the best RAM I have used for overclocking and I was easily able to get them to run at 2666MHz 10-12-12-30-190 with a slight increase in voltage from 1.65 to 1.675v. Even setting the command rate from 2 to 1 was no trouble for these DIMMS.
140825182228_zps63af5428.jpg~original
The full 16GB of RAM ran at these settings without issue.
Performance results.
aida_zps77686316.png~original
super_pigg_zps445e47d0.png~original
cine_zpsdac17396.png~original
3dmarkskydiver_zps9b94377e.png~original
pcmark_zpsb943b7ab.png~original
borderlands2_zps85901b32.png~original
battlefiedl4_zpsab1964e5.png~original
thief_zps1e5164bc.png~original
Conclusion.
The Corsair Dominator Platinum RAM is the best RAM I have used to date. It has excellent stock performance and the overclocking abilities are superb. The RAM is expensive but it is well made and looks gorgeous, if you are the sort of end user that wants the absolute best and likes chasing performance numbers then this is the RAM for you.
It also seems to have greater compatibility with my boards, especially my X79-UP4 and i7 3930K that usually doesn't work with my Kingston kit when trying to run at XMP profile of 2400MHz CAS11 and I have to instead run at 2133MHz. The Corsair kit boots perfectly into Windows when set to the XMP profile and runs spot on.
Pros.
Amazing looks.
Top performance.
Amazing overclocking.
Cons.
Expensive.
Additional.
I also tried one of the Team AU/HiCookie 2666MHz with tight timings memory presets found in the memory section of the BIOS which also booted and worked fine.
140827154326_zps89d249c3.jpg~original
n_zps9836dbd1.png~original
As you can see those are some significant lower numbers when compared to the XMP settings.
Untitled_zps4496b8c5.png~original
This is some of the finest DDR3 on the market and gets a gold from me.
There are different CPUZ versions with different skins available to download.
So if you have an ROG board you can get one to match. ASrock and Gigabyte Gaming is also available.
I know this is an old thread, just wondering is this memory still available as i already have this version cas9, and for some reason cant find any to make at least 32gb or 64gb if lucky... if anyone knows were, to get hands on them cheap let me know or direct me to were it might be on the forum, as my search on here is not going well.
Might not help but I'm getting rid of some of the C11 version in the MM, I could try and test it at these timings if you are interested?
