[PIC_THREAD] Wildlife, Animals, Birds, Zoo
22 May 2003
Haha yeah hes always got his tongue out, I like to photograph him when he's got a longer coat but he does get hot when its not clipped, also he can't see a damn thing so I end up having to get the tennis balls for him.
For the price I love the Helios, nice portrait lens I think at that length.
21 Oct 2002
30 miles north of London
well this thread has become very cute lol
An old shot from my first kit (300D + Tamron 28-300) might help balance it a bit ;)
And
And
7 Dec 2002
Aye, they are rather vocal. I don't go looking for waders/seabirds but I see a lot of oystercatchers on Mull.
19 Jul 2004
Shoreham by Sea
Collins Bird Guide, by Lars Svensson, is one of the best books for ids. All illustrations rather than photos.
Yeah there's undoubtedly better ways to ID birds but truth be told, I'm too lazy to look them up unless I keep seeing them and eventually curiosity gets the better of me lol :)
Why look things up when there's a load of other people out there that will do it for you? :D
19 Jan 2007
Northampton
Yeah, I currently use my old 75-300 for them so as I get within range the blighters usually fly off.:)
I did get a corker the other week, not as sharp but I love the cartoon smile:
Your 2 dragonflies mating is very sharp, I took loads of piccies the other day but few were as sharp:
Although I did see a Grass Snake pottering over the other side of the stream:
19 Jul 2004
Shoreham by Sea
Yeah the lens definitely helps :) Dragonflies are tricky because they're often quite skittish but occasionally you can find them when they're cold or if they're busy hunting rather than patrolling their spots.
If they're cold then you can get up to them with the sharpest lens you have and snap away. If they're hunting then they might tolerate you whilst they look for their snacks but the rest of the time I find they don't sit still for long and they often sit in spots you can't get to easily :/
The first few you've posted are pretty sharp :) The second lot seem to be taken with less light and higher ISO so you'll lose some sharpness there.
You can also use extension tubes even with longer lenses to get a bit more magnification.
19 Jan 2007
Northampton
Thanks for the feedback.
My 75-300 is at times shocking, CA is a big issue on some subjects and it is at its sharpest at 150mm or so.
I've rented a 70-200 F4L for this weekend, I'm thinking of buying one and using it with extension tubes for butterflies, dragonflies etc and without as a walkabout lens. Hopefully the optics will be better.
Edit: Minimum focusing distance is 1.5m or so on the 75-300 and 1.2m on the 70-200 F4L, so not a lot in it really.
19 Jul 2004
Shoreham by Sea
Yeah as sharp as my 70-200mm F4L was, it wasn't great for small stuff. My 200-400mm is surprisingly good since it's a 2m minimum focus even at 560mm and I can also put in an extension tube or a 1.4x extender for zoomses.
I've seen people get very good results with reversed lenses so that's definitely worth a look but if you still want distance then I'm not sure how that fares.
