4K or 30 inch monitor upgrade.
11 Nov 2009
Edinburgh
I am thinking that perhaps 670 SLI will not cut it with a 4K monitor for gaming though I am open to correction on that point. So any advice perhaps on a 30 inch monitor? Don't haver budget as such will just save to afford it.
__________________
2560x1440 or 2560x1080 could be OK for SLI 670s.
After that how big monitor, it all depends how much space you have.
I am looking for an upgrade from my 27" Dell Ultrasharp. Space is not an issue.
I also been looking at upgrading from my Dell 27" monitor and I been thinking there really are no good monitors bigger then 27" with support for over 60hz for gaming so am now thinking of maybe trying one the Asus PG278Q ROG Swift monitors..
Asus PG278Q ROG Swift 27" G-Sync 144Hz Gaming Widescreen LED Slim Bezel Monitor
http://www.overclockers.co.uk/showproduct.php?prodid=MO-070-AS&groupid=17&catid=948
Kronos I am a 30" IPS panel user, and actually have some I might part with, if you're looking to adventure into something that size.
I sent friend invite, hit me up if you want to know more or have any further questions.
