Best GPU for £200-250?
Wait until you can afford a 970!
Unless you have a 486 DX2 66, you will still get better performance from a 970 than from, say, a 770.
Your CPU might be weak and you might get better performance if you upgrade it, but a 970 is still better than a 770/760 or whatever else you are thinking of getting because of your weak cpu.
Buy the 970, then save for a CPU upgrade, and this time when picking a CPU don't buy anything labelled "AMD", it's not 2001 anymore :P
But, but, I've always gone with AMD aha.
I'm more concerned about the mobo, the 8350 has decent benchmarks vs i5 and some i7 chips
Mobo won't ever give you a measurable GPU performance boost. For single card, it's x16 PCIe so that's all that makes any difference.
I used to always go AMD too, from K6-2 to Athlon 64 days, but now, they are unquestionably behind by a margin, which is a shame because more competition would be good :(
You're still well behind an i7, and will still improve performance substantially if you come to the Blue Team ;)
http://www.bit-tech.net/hardware/2012/11/06/amd-fx-8350-review/6
If you have got an aftermarket cooler overclock the CPU, if you havent got an aftermarket cooler get one and overclock the CPU.
The 970 is a good card for the money but dont discount the 290/290x either. Comparable perfomance but with a larger power draw/heat factor, though if you pay a lot of BF4 or planning on any future Mantle featured game (Star Citizen for example) your CPU wont be a bottleneck.
Apologies for the noob question, but how concerned should I be about the manufacturer, if at all?
If I am parting with 250 I'd rather spend that little bit extra for the reliability and peace of mind.
I tend to stay way clear of MSI due to problems with a previous card
Nothing wrong with MSI cards. OcUK will deal with any warranty issue also.
If you don't like it just send it back under DSR, but you're best choice would be a £270 GTX970 or a £215 R9 290.
OcUK last week had the same GTX780 (but oem not retail boxed) selling at £193.
That was epic value for £££
