OcUK Staff
- 26 Nov 2014
- Stoke
Corsair have decided that Xmas has come early and reduced the price on several PSU's and Cases, so fill your boots (or stockings!) Only limited stock available so if you want it, buy it quickly!
Corsair RM Series RM 1000 '80+ Gold' 1000W Power Supply (CP-9020062-UK) @ £119.99 inc VAT
Corsair RM Series power supplies are fully modular and optimized for silence and high efficiency. Zero RPM Fan Mode means that the fan doesn’t even spin until the power supply is under heavy load, and the fan is custom-designed for low noise operation even at high loads. 80 PLUS Gold rated efficiency saves you money on your power bill, and the flat black cables are fully modular, so you can enjoy fast, neat builds. And, like all Corsair power supplies, RM Series is built with high-quality components and is guaranteed to deliver clean, stable, continuous power. Connect it to your Corsair Link system and you can even monitor fan speed and +12V current directly from your desktop (additional cable required for 450W-850W units).
Product features:
- Optimized for Silence: The components used to manufacture the RM Series are manufactured specifically for excellent performance and low audible noise.
- 80 PLUS Gold-certified Efficiency: Highly efficient RM Series power supplies produce less heat and have lower operating costs.
- Flat black, Low-Profile Modular Cables: You can use only the cables you need, and leave the rest in the box for fast, easy, and great-looking builds.
- Reliable, Continuous Power Delivery: Corsair uses high-quality internal components, and RM Series power supplies are guaranteed to deliver clean, stable, continuous power.
- Corsair Link Compatible: RM Series power supplies connect to Corsair Link software for real-time monitoring of fan speed and power delivery directly from your desktop. Additional hardware required for 450W-850W units.
- The latest ATX12V v2.4 and EPS 2.92 standards and it is backward compatible with ATX12V 2.2, 2.31 and ATX12V 2.01 systems.
- 4th generation Intel® Core™ processor Ready (Intel Haswell and Z78 motherboards)
- 80PLUS Gold certified, delivering over 92% energy efficiency at real world load conditions.
- The completely modular cable system allows you to use only the cables you need.
- Low-profile, flat cable design reduces air friction and helps maximize airflow through your computer’s chassis.
- High-quality capacitors provide uncompromised performance and reliability.
- A five year warranty and lifetime access to Corsair’s legendary technical support and customer service.
- Active Power Factor Correction (PFC) with PF value of 0.99.
- 135MM NR135L Noise reducing fan. MTBF: 100,000 Hours
- Universal AC input from 100~240V.
- Multi-GPU Ready
- Over-voltage and over-current protection, under-voltage protection, and short circuit protection, over power protection, over temperature protection provide maximum safety to your critical system components.
- Safety and Agency Approvals: FCC, ICES, CE, C TUV US, RCM, TUV, CB, CCC, BSMI, GOST, ROHS, WEEE, ROHS, KC
Was £155.99 Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
Corsair RM Series RM 650 '80+ Gold' 650W Power Supply (CP-9020054-UK) @ £71.99 inc VAT
Product features:
- The latest ATX12V v2.4 and EPS 2.92 standards and it is backward compatible with ATX12V 2.2, 2.31 and ATX12V 2.01 systems.<br />
- Multi-GPU Ready
- Over-voltage and over-current protection, under-voltage protection, and short circuit protection, over power protection, over temperature protection provide maximum safety to your critical system <br />components.
Was £99.95 Inc. VAT
Only £71.99 inc VAT.
ORDER NOW
Corsair Graphite 380T Portable Mini ITX Case - Black (CC-9011061-WW) @ £91.99 inc VAT
The Graphite Series 380T packs a powerful punch in a portable Mini-ITX PC case. A built-in carrying handle makes transport a breeze. It’s easy to build the road-ready computer of your dreams within a spacious, easy to access interior with room for an extra-long graphics card. You can keep things cool with mounts for up to six fans and a convenient front panel three-speed fan controller.
The Graphite Series 380T Mini-ITX PC case doesn’t make any comprises inside or out. The sleek design derives from Corsair’s most-celebrated computer cases -- featuring eye-catching rounded corners as well as multiple color options. A built-in carrying handle lets you take it anywhere with ease.
Fine-tune air-cooling performance with the three-speed fan controller. Visible through the windowed side panels, the roomy and easy to access interior delivers major real estate for your next rig with space for a full-length graphics card, six fans, and four drives. Plug in your USB 3.0 devices and headset through the front panel. Now you’re ready to hit the road in style.
Features:
- Aesthetics that impress: sleek design, rounded corners, and easy to remove windowed side panels
- Built-in carrying handle makes it a portable powerhouse
- Included 140mm LED intake fan and 120mm exhaust fan
- Control freak? Customize cooling and noise level with the convenient three-speed fan controller
- Swap drives easily -- without tools -- in and out of the two 3.5¡¨ and two 2.5¡¨ drive bays
- Built-in internal lighting with to show off your system
- Easy connectivity with front panel USB 3.0, headphone, and microphone ports
- Maximum CPU Cooler Height -150mm
- Maximum GPU Length - 290mm
- Maximum PSU Length - 160mm
- Mounts for 5 Fans
- Front fan mounts: 1 x 200/140mm, 2 x 120mm
- Side fan mounts: 2 x 120mm
- Rear fan mounts: 1 x 120mm
Radiator compatibility:
- Front - 140mm or 120mm
- Bottom - 240mm
- Rear - 120mm
Was £99.95 Inc. VAT
Only £91.99 inc VAT.
ORDER NOW
Corsair Graphite 380T Portable Mini ITX Case - White (CC-9011060-WW) @ £99.95 inc VAT
Features:
- Mounts for 5 Fans
- Bottom - 240mm
- Rear - 120mm
Was £109.99 Inc. VAT
Only £99.95 inc VAT.
ORDER NOW
Corsair Obsidian Series 250D Mini ITX Compact Gaming Case - Black (CC-9011047-WW) @ £62.99 inc VAT
If you want to build a Mini ITX system without compromising expansion, flexibility, or performance, the Obsidian Series 250D is your answer. Though it's small on the outside, the 250D has room for standard components like a full-size 5.25" optical drive, a full-length GPU, a 240mm radiator, and even a full-size ATX power supply. The sleek, aluminum front fascia provides the striking yet subtle design that Obsidian Series cases are known for, and a top window gives you a close-up view of your high-performance components. The 250D is a great choice if you want full size performance in a small space.
Specifications:-
- Aluminum front fascia and thick steel construction.
- Overall dimensions 290mm (H) x 277mm (W) x 351mm (D)
- Top window for component visibility.
- Thumbscrew backplate removal for PSU and hard drive access.
- Easily removed dust filters on all intakes.
- Simultaneously fit two 3.5"/2.5" drives, two 2.5" drives, one 5.25" drive, a full sized PSU, a 290mm long GPU, and a 240mm radiator.
- Front panel USB 3.0, headphone and mic ports, and power and reset buttons.
- Innovative three panel removal for sides and top panel, with thumbscrews.
- Front fan 200mm, 140mm, or 120mm compatible (AF140L 140mm included)
- Side fans dual 120mm compatible (AF120L 120mm included)
- Rear fans dual 80mm compatible
- Tons of cable routing tie downs for easy cable maintenance.
- Tool free installation of all drives.
Was £69.99 Inc. VAT
Only £62.99 inc VAT.
ORDER NOW
Product features:
- Multi-GPU Ready
ORDER NOW
Product features:
- Multi-GPU Ready
Was £99.95 Inc. VAT
ORDER NOW
Features:
- Mounts for 5 Fans
- Bottom - 240mm
- Rear - 120mm
Was £99.95 Inc. VAT
ORDER NOW
Features:
- Mounts for 5 Fans
- Bottom - 240mm
- Rear - 120mm
ORDER NOW
Specifications:-
Was £69.99 Inc. VAT
ORDER NOW
